I have tons of MiniDV tapes that I would like to work with on my PC Desktop; however, my computer doesn't seem to have a 6 pin firewire port.
Can anyone tell me what my most practical option is? Thanks.
Results 1 to 14 of 14
See this post, seems as if WinDV works fine in Win 7:
https://forum.videohelp.com/threads/332858-Looking-for-Win7-software-to-capture-AV-DV-v...ighlight=windv
Firewire card does not come (usually) with any software.
The type of editing you want to do will determine your software needs. -
even after buying an ieee1394 card you will still need to purchase editing software. vegas pro, and premiere pro are among the best for windows, but how much had you wanted to spend???
WinDV is fine for "capture". What you are doing is moving the data from your DV tapes to a file. There is no loss if done correctly. Data doesn't care about date.
DV is high quality and frame by frame so be prepared for 13 GB per hour.
The format is ideal for editing. Compression is applied after editing.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
WinDV is fine...a simple ap using little resources...and is all you need
I'd suggest an entry level editor like Vegas Movie Studio which has one of the biggest bangs for the buck -
Firstly, I apologize for being so dense.
So, what I gather is that capturing is one issue (for which WinDV apparently works well) and editing is another issue.
Do any of the editing software programs do both (or maybe they all do it - I don't know)? It doesn't seem feasible to have to capture with one program then edit with another.
While writing this I noticed you posed about Vegas Movie Studio so I'll check that out...thanks again. -
Vegas includes a capture program but it is multi-format, requires configuration and confusing to to novice. WinDV is DV focused and difficult to screw up for the newbie (no offense).
There is no difference in the quality. It is just moving bits.
WinDV is a user GUI on top of Windows DirectShow. ... Now I'm confusing you, sorry.Last edited by edDV; 5th Apr 2011 at 23:09.
Non taken, thanks for your explanation/recommendation.
While looking inot Vegas I noticed I can download from Author/Developer site which sends me to Sony offering Vegas Movie Studio HD Platinum 10 for $94.95 or from author site (direct link) which prompts a File Download - Security Warning and (I guess) the option to download for what...free? What do you recommend? -
Corrupted MiniDV tape
By glitchee in forum MediaReplies: 1Last Post: 29th Feb 2012, 15:19 -
miniDV tape question
By minidv2dvd in forum Capturing and VCRReplies: 3Last Post: 7th Dec 2010, 18:47 -
MiniDV Tape Question
By GlamourDave in forum Newbie / General discussionsReplies: 4Last Post: 13th May 2008, 23:08 -
Best miniDV Tape Brand/Model for archiving?
By nowhereman83 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 16th Apr 2008, 14:47 -
how to? minidv tape to dvd best options
By pantsdavies in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 11Last Post: 9th Nov 2007, 21:35
