I've got a couple of HD movies which I've recored using a dvr (files are in ts container) and converted to mp4 (h.264 + AAC stereo). While those files run fine on my computer, I can't get them to play on a Xbox 360.
The problem seems to be caused by the video itself - any idea how I can fix this?
EDIT: I've already tried to change the format setting down to 3.1 (see above), but without luck.Code:Format : MPEG-4 Format profile : Base Media / Version 2 Codec ID : mp42 File size : 2.78 GiB Duration : 1h 17mn Overall bit rate : 5 109 Kbps Encoded date : UTC 2011-04-05 11:28:21 Tagged date : UTC 2011-04-05 11:32:55 Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : High@L4.0 Format settings, CABAC : Yes Format settings, ReFrames : 4 frames Muxing mode : Container profile=Main@3.1 Codec ID : avc1 Codec ID/Info : Advanced Video Coding Duration : 1h 17mn Bit rate mode : Variable Bit rate : 5 106 Kbps Width : 1 440 pixels Height : 1 080 pixels Display aspect ratio : 4:3 Original display aspect ratio : 16:9 Frame rate mode : Variable Frame rate : 28.247 fps Original frame rate : 25.000 fps Minimum frame rate : 12.500 fps Maximum frame rate : 50.000 fps Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : MBAFF Bits/(Pixel*Frame) : 0.116 Stream size : 2.78 GiB (100%) Encoded date : UTC 2011-04-05 11:28:25 Tagged date : UTC 2011-04-05 11:32:54 Color primaries : BT.709-5, BT.1361, IEC 61966-2-4, SMPTE RP177 Transfer characteristics : BT.709-5, BT.1361 Matrix coefficients : BT.709-5, BT.1361, IEC 61966-2-4 709, SMPTE RP177
How do I make a H.264 .TS File play normally on xbox 360 extender?
By bubbrubb in forum Video ConversionReplies: 2Last Post: 6th Feb 2010, 13:53 -
Convert h.264 MP4 w/AAC 5.1 audio to AVI file w/AC3 5.1 audio for Xbox 360
By ycrazyy in forum Newbie / General discussionsReplies: 6Last Post: 14th Jan 2010, 15:25 -
Aspect ratio incorrect when playing converted mp4 file on xbox 360
By ArtOfLosingMFZB in forum Newbie / General discussionsReplies: 7Last Post: 31st Aug 2009, 12:52 -
Xbox 360 h.264 HD video playing back skippy - Need Help
By cbstryker in forum Video ConversionReplies: 2Last Post: 21st Dec 2008, 01:24 -
What's the Best Bitrate for Converting DVDs to .264 MP4 files for xbox 360?
By keyed in forum Video ConversionReplies: 1Last Post: 3rd Feb 2008, 02:04
