I have a class 4 sdhc card for my Canon Rebel T2i, but the video seems like it could be better. Should I get a class 6 or Class 10 card?
James
Results 1 to 9 of 9
Using a too slow SDHC card will usually result in dropouts or corrupted video. But wouldn't make much if any difference in quality, just capture and transfer speed. With a still camera, a faster card helps the camera cycle faster to be ready for the next shot.
But I would use at least a class six card with video. Class 10 probably would be overkill and just cost a lot more, unless your camera specifically says it will work.
BTW, the class is supposed to be the sustained transfer rate in MB/s. Class 6 = 6MB/s. But those ratings are from the manufacturer, so may not be accurate. http://en.wikipedia.org/wiki/Secure_Digital -
you would be lucky if u got a class 10 and it actually got the 10mb they say it does...most don't get near it. i would just go with a 6mb. A lot have tried the 10's and some just aren't up to snuff
Further,
Class 10 probably won't help a Canon Rebel T2i much but if you had one of those 1920x1080 60p Panasonics it would be a near requirement. Ignore the "Class 6 = 6MB/s" spec. That is for bursts not minutes of sustained data transfer. Also figure in that file fragmentation and wear cycles slow transfer rates.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
For a t2i, it is recommended you use a class 6 minimum. I have a t2i and have used both class 6 and class 10 cards. My t2i is hacked via Magic Lantern firmware that allows me to set encoding bitrates. So far, I have yet to see any advantage to using a class 10 card over a class 6 card.
My camera is capable of encoding up to 120 Mb/s which will far exceed any class speed currently available.............Got my retirement plans all set. Looks like I only have to work another 5 years after I die........ -
I have the Canon t2i. I also hacked it via Magic Lantern firmware. The stock bitrate is around 47 Mb/s. Magic Lantern allows in camera encoding rates from 6 Mb/s - 120 Mb/s. There is no card currently available that can sustain full 120 Mb/s for more than a few seconds at a time.
Video editing class
By RobynW in forum Off topicReplies: 2Last Post: 4th Jun 2011, 13:21 -
Making a Sr Class DVD slideshow.
By ingeborgdot in forum Authoring (DVD)Replies: 35Last Post: 19th Apr 2010, 02:11 -
ImageGrebber II Class Not Registered Error
By DJboutit in forum Newbie / General discussionsReplies: 2Last Post: 27th Feb 2010, 10:51 -
Class 4 and Class 6 SDHC cards with Canon HF200
By eteune in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 6Last Post: 25th Dec 2009, 15:10 -
SD Card Class 2 vs Class 6
By DJboutit in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 6Last Post: 23rd Jul 2009, 16:59
