I copied a DVD, and if it burn these files to a blank CD i will get a DVD that runs in my DVD player. But when i copied the exact same files to a USB player, it can't detect any data? Is there any programs to fix that?
Check your owners manual to see what types of video file the USB functionality can view. Most new machines will play MPEG 1,2, AVI, XVID, DIVIX. If you want to be able to play VTS_VOB from a USB flash drive you should think about getting a HD media player.
USB DVD player - scenes with water and some audio struggles to play......
By Cieran in forum DVD & Blu-ray PlayersReplies: 3Last Post: 21st Nov 2011, 19:05 -
how to play mkv file on dvd player with usb
By ashe09 in forum Newbie / General discussionsReplies: 1Last Post: 12th Nov 2011, 00:46 -
Looking for DVD player w/USB that will recognize DVD menus through USB
By b20828 in forum DVD & Blu-ray PlayersReplies: 4Last Post: 30th Dec 2010, 09:43 -
Can I play video files from my PC HD, through my DVD player,using USB port?
By fgtan in forum DVD & Blu-ray PlayersReplies: 2Last Post: 21st Nov 2008, 14:10 -
Whick dvd player with usb port can play rmvb file?
By haitang in forum DVD & Blu-ray PlayersReplies: 3Last Post: 19th Jun 2007, 00:31
