My new camcorder can record either 1080i 60 fields/sec vs 1080p 30 frames/sec. What are the advantages/disadvantages of recording 1080i 60 fields/sec vs 1080p 30 frames/sec?
1080i can exchange resolution with smooth motion - 1080p is always fixed - for static scenes 1080i should be quite similar to 1080p, for dynamic scene 1080i will give smoother motion at a cost of vertical resolution however human eye is less sensitive for details in moving scenes - 1080i seems to be better suited to human eye characteristic. If You can go for 1080p60 if not - tough choice - result will be highly related to scene.
but i can be converted in quite simple way to 1080i30 or 720p60 or 1080p30 for example - source is most important part and support for 1080p60 slowly improving.
1080i 29.97 frames/sec to DVD compliant SD using Avisynth and HC encoder
By johnnyquid in forum Video ConversionReplies: 2Last Post: 25th Jul 2011, 15:24 -
SANYO VPC-GH4 1080i 60 fields/sec reported as progressive at 60fps
By johnnyquid in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 16th May 2011, 21:43 -
Burn't DVDs skip 1 to about 5 frames every 30 sec. or so, please help.
By Fluffin in forum Authoring (DVD)Replies: 5Last Post: 21st Apr 2008, 10:46 -
AVICodec reports wrong frames per sec
By igorek in forum Newbie / General discussionsReplies: 1Last Post: 6th Sep 2007, 19:27 -
Padding out avi files to 25 frames per sec.
By yowie in forum Newbie / General discussionsReplies: 8Last Post: 12th May 2007, 08:52
