my kids have a panasonic dvd player that won't stay closed even when there is no disk,i took the top off cause i thought there was a dvd stuck in it AGAIN ,there is not,i blew the dust out with a can of air,the open close button works cause i can open close repeatedly and that works fine,it won't even stay closed when you close it and shut the power off,it waits a few seconds then opens then says bye,please help if you can.thanks
kids are pretty rough on everything
a few things you could try:
is there a remote control stuck in the couch? perhaps this is sending a open tray signal
try tugging on the tray gently...perhaps the kids pushed it in and it's skipped a tooth making it think it's not closed all the way
google for similar incidents and remedies -
turn it off and close it yourself (it won't damage it) then turn it back on and see if it open/closes properly.
The player needs to replaced. What is happening the drive door is not making contact to the switch that lets the player know that the door is closed or the switching transistor has malfunctioned.
One more thing you could try is resetting the unit by unplugging it for around 5 minutes. Plug it back, and hopefully it works.
-The Mang
DVD Recorder drive will NOT stay closed
By seskanda in forum DVD & Blu-ray RecordersReplies: 12Last Post: 4th Feb 2015, 00:31 -
Harman Kardon DVD-22 won't open the disc tray
By edong in forum DVD & Blu-ray PlayersReplies: 0Last Post: 13th May 2011, 17:11 -
Sony DRu 840 dvd RW Tray won't stay closed
By scustalow in forum ComputerReplies: 1Last Post: 30th Apr 2008, 12:39 -
PC Monitor Won't Stay On
By The Monkees in forum ComputerReplies: 4Last Post: 11th Mar 2008, 00:15 -
DVD tray won't eject...
By zowiemagic in forum DVD & Blu-ray RecordersReplies: 6Last Post: 25th Dec 2007, 16:03
