Results 1 to 10 of 10
  1. Hi i need help with KMplayer. I just installed it because VLC player is having problems playing some of my videos. Whenever i start KMplayer and play a video i get this dang error.
    how do i fix it?
    Which version?
    Are you running it adminstrator mode(right click on it and run as adminstrator)?
    Tried google the "url.dll" error message?
  3. ver 3.0.0.1439
    I ran it as admin and same error
    yes i did google it. i read lots of info, didn't find anything that helps
  4. ver 3.0.0.1439
    Mar 2008
    What OS? Windows 7 ? 64 bit ?
  6. windows 7 x64
    Mar 2008
    Try following the steps in the support article:
    http://support.microsoft.com/default.aspx?scid=kb;EN-US;929833
  8. okay i tried what you said, followed the command promp and got this" windows resource protection found corrupt files but was unable to fix some of them" ummm now what... i'm still looking on google for help on fixing the sfc scan thingy.
    Mar 2008
    IN the article I mentioned above, find the section with this heading:
    "To determine which files could not be repaired by the System File Checker tool, follow these steps:"
    You'll see it provides some details about reviewing the log from the above scan, and identifying files it couldn't fix.
    It goes onto describe a method for replacing files that could not be replaced automatically.
  10. thanks davexnet for the help, sorry i would of replied earlier but i was busy.
