I live in a studio apt and have an htpc for entertainment purposes and use my desktop for work - especially downloading, editing, rendering. They are about 22 feet apart. I am going to spring for a dual core very soon so that I can play blue ray disks as well as do some tasks that require more than a p4. My problem is that the htpc is where I watch blue rays and dvd, while the desktop pc is where I need the dual core for my work - I need the same resources available to both computers but don't have enough $$ to buy duplicates. How can I share? I am considering putting the blueray and my dual core in my desktop and then using a kvm to connect it to my htpc. as mentioned the cable would be able 22 feet long to do that. I have read that vga cables can be much longer than that and not have a reduction in video quality but I am not sure if that is true with BR. that is one option.
Do I have other options? One thing i am hoping to do is to minimize the number of wires and cables I have in my home. Both mobo's have 10/100/1000 network cards. I am going to do a peer to peer with the 1000 speed. Is it possible to play the br on my desktop and stream the video output through the network to the htpc? What options do I have for sound? I will have a 5.1 sound system in a couple of weeks, after I buy my dual core.
You can share the root of the Blu-ray drive but that will be a file level share. You won't be able to watch encrypted Blu-ray discs (maybe if you use DVDFab's Passkey), or write Blu-ray discs, via the share. The simplest solution is just to get a Blu-ray drive in your new computer. What else are you looking to share between the two computers?
rip the blurays to the htpc's hard drive as mkv or even full folders if you have the space. then use dlna software so you can easily share any content over a network.
Serviio might work for you and it's free.--
Since it's computer to computer I wouldn't bother with DLNA. Just use normal network shares.
h264 encoding does not use all system resources
By sharkbite in forum Video ConversionReplies: 3Last Post: 28th Feb 2012, 19:16 -
Resources Needed to Remove DRM From Video
By Rogcliff in forum Newbie / General discussionsReplies: 1Last Post: 2nd Sep 2011, 18:39 -
Free resources in the internet
By Yawar in forum EditingReplies: 3Last Post: 18th Aug 2010, 06:59 -
WDTV Live Media Player and the like vs. Desktop with HDMI port (HTPC?)
By edong in forum Media Center PC / MediaCentersReplies: 13Last Post: 19th Mar 2010, 13:30 -
Vegas 7.0 Rendering - not using full CPU resources
By tarrickb in forum EditingReplies: 1Last Post: 6th Sep 2007, 14:19
