In The Name Of Allah The compassionate merciful
Hello ;
Can this file be converted to any other video format ?
I(humble) have tried to the work with ffmpeg and avidemux in linux and a windows app but all output files had not sound .
This file is recorded file from TV with VLC .
an example > http://dehqann.byethost15.com/1.ts
How to convert it with no problem?
Regards dehqan
Results 1 to 9 of 9
Firstly what type of .ts file is it?
Sometimes people describe the DVD format of VIDEO_TS (folder) as a "ts" file.
More correctly it refers to a transmission stream as transmitted by digital TV and can contain video (sometimes mpeg2 or H264 and subtitles and audio in various formats)
How about posting more details like a log file from MediaInfo then a sensible discussion can follow.SONY 75" Full array 200Hz LED TV, Yamaha A1070 amp, Zidoo UHD3000, BeyonWiz PVR V2 (Enigma2 clone), Chromecast, Windows 11 Professional, QNAP NAS TS851 -
Have you tried vlc to convert it ? since you captured with it
The audio is LATM/LOAS AAC, and not very many applications support this
Other options that are verifed to work are:
1) to use graphstudio using lavc for the source filter and audio decoder, construct a directshow graph , and use avisynth to encode . You can convert the video using normal methods, or use graphstudio for the video as well
EDIT: the lav decoder only decodes as 1 channel so I would use method #2
2) demux using eac3to or dgavcindex, and convert the audio using winamp to wav . The rest of the conversion for video is using normal methods -
Thank you for your attentions ;
Would someone give me a tested way to convert that .ts file , and would you test your idea with example file and check if your solution works or not completely ?
I(humble) have tried to the work with ffmpeg and avidemux and also VLC in linux and a windows app but all output files had not sound .
@ poisondeathray I(humble) am not familiar with video decoding ,encoding,demuxing and remuxing and so ... and just require a way to convert that .ts file to another known format that can be played with know players such as media player .
Yes , That .ts file is recorded video from digital TV with VLC .
and this is some information ,despite you could see example file yourself > http://pastebin.com/DQuyWAQeLast edited by a.dehqan; 3rd Apr 2011 at 02:21.
W Alaikum Al Salam
I managed to convert your 1.ts file into 1.mp4 using SUPER from http://www.erightsoft.com/SUPER.html. It is a free encoder, you simply select MP4 as output format and click start encoding and you should have your 1.mp4 in the same folder. You could try using other formats.
The program identified the language as Persian but in your sample I could not hear any spoken words, only the sound of the big motor. -
Hello ;
I(humble) have used Super for converting , but .mp4 output file has less quality .
Some other formats have been tested also , in one audio had a delay with video .
@poisondeathray What is your choice ? Has output file a good quality ?
Regards dehqan
Hi
Did you try using better settings in super (higher bitrate) ?
For the method I suggested - I don't know if these programs work on linux or wine
This method frameserves uncompressed video & audio. So your choice of encoder and settings (bitrate) determines the final quality. If you choose lossless format, you get 100% identical quality as the original, but filesize will be large
Audio bitrate is very low in source to begin with (low quailty) , and LATM/LOAS is not compatible with many softwares so you should re-encode the audio anyway
When demuxing the audio, the delay value is written into the filename , but your sample is too short to determine if there were sync issues. Regardless you can easily use the delay value or shift the audio
It's common for TS recordings to have drop outs and sync issues. IF you have these, you have to repair them first, or they will never be in sync
Converting an AVI file in Toast PROBLEM!!!!!!!!!!!
By thasco in forum MacReplies: 10Last Post: 14th Dec 2010, 10:44 -
Audio problem while converting trp file
By ngr in forum Video ConversionReplies: 3Last Post: 13th Oct 2010, 14:22 -
Problem converting .wmv file
By AdamUK in forum MacReplies: 3Last Post: 24th Apr 2008, 07:40 -
Problem Converting MKV file with MKVtoVOB
By AllenM in forum Video ConversionReplies: 5Last Post: 2nd Mar 2008, 12:59 -
Problem converting .MKV file
By craig3975 in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 13th Sep 2007, 12:19
