  1. How do i do 2pass encoding with hc encoder all i see is 1pass vbr
    i can't find 2pass...help
    also whats a good bit rate for encoding dvd I'm using '6000' in hc encoder.
  2. uncheckmark 1pass vbr on the 1st tab, and constant quantization on the 2nd tab, and it will automatically do 2 passes. The default settings are 2 passes
    use a bitrate calculator to find optimal bitrate
    https://www.videohelp.com/calc.htm
  3. thank you for the help poisondeathray
    i was going crazy trying to find 2pass encoding and thanks
    for suggestion about the bitrate calculator.
    canada
    Not news,post moved to video conversion forum.
