Friends,
I've a live show's recording that the audio is too loud. I would like to know if exists some way to adjust It?
I'm sending as an attachment a sample of the recording, so if possible, tell me if there a some way to adjust It.
Thanks for my poor english.
Results 1 to 12 of 12
MP3Directcut, ctrl A to select all, ctrl M to normalize and ctrl W to save. Or you can just adjust the level manually (forget the key combo for that).
once the peaks are clipped off they are gone for good, there is no way to recover the lost part of the audio.
jagabo, I've the original source in wav format. I attached as MP3 only for a sample.
aedipuss, what the software I'll have to use to do what you said? -
Going back to the original WAV isn't going to help. All you're going to get is a less loud version of the same blown out audio. Ie, it will sound the same (completely unidentifiable) just less loud.
You can use Audacity as manono mentioned. Audacity also has a peak restoration filter which works with slightly blown out peaks. But your audio way too far gone.Last edited by jagabo; 2nd Apr 2011 at 20:00.
I've used a VST plugin called Relife in the past with some good results. However, I couldn't get anything useful with your mp3.
Here's where to get it if you want to give it a try.
http://terrywest.nl/utils.html -
You get the DLLs and stick them in the Plugins folder of Audacity. Then after opening Audacity go Edit->Preferences->Rescan VST Effects... Close Audacity and then reopen it. After it does the scanning it shows up as two of the effects, TWest Productions: Relife and Relife Mono.
Thanks, davexnet, I can use this. -
You're never going to get anything listenable out of that. Give and and call it a learning experience.
Adjust audio level
By drgt in forum Newbie / General discussionsReplies: 7Last Post: 11th Aug 2011, 13:03 -
Precise audio adjust in Premiere pro cs5
By ihmcjacky in forum EditingReplies: 1Last Post: 16th Jan 2011, 09:49 -
Is there such a tool that would go through my AVI and adjust the audio lvl?
By Chrushev in forum RestorationReplies: 3Last Post: 22nd Oct 2009, 16:36 -
How to adjust the audio to be all the same in every video file added todvd?
By f-zer0 in forum AudioReplies: 5Last Post: 27th Feb 2008, 18:01 -
Adjust audio volume with FairUse Wizard or later
By 2dpikke in forum DVD RippingReplies: 5Last Post: 5th Jul 2007, 23:40
