Hi, can somebody please tell me why when trying to create a video disc, it expands the origing avi file? EG. 3.9GB of actual video expands to 21.52GB? My dad used to use DVD Movie Factory 2SE and it did not do this. This is kind of annoying. Wondering if there is something that can be set so that this can be achieved? So 3.9GB will actually fit on a regular DVD 4.7G? 3.9GB is 20 .avi videos which are 20min each. Thanks in advance.
Results 1 to 9 of 9
Welcome orientaldragon
You simply cannot achieve fitting "400 minutes" to a single dvd, dvd dl for that matter ... even if possible the quality would be rubbish.
Break it down into 120 minute segments and use multiple dvd-r's. -
You can easily fit 400 minutes on a DVD. All you have to do is use the right bitrate, about 1350 kbps. With that low a bitrate you will want to use a 352x240 frame size (or 352x288 PAL). Unless it's a slideshow.
for future reference, corel/ulead also have their own help forums
Thanks for the reply. Yes, I can do that, but I wanted to know the reason why every file is expanded to be bigger in this version of DVD MovieFactory. Older version 2.0SE does not do this. 3.9GB is 3.9GB not 21.5GB.
And your dad probably used a dvd-compliant mpeg2 file which meant that DVD movie factory did not re-encode the source clip ie the size remained the same.
But I am equally sure that he did not try to put 400 minutes on to one dvd disk unless, as has been stated he was using a small frame size. Small frame sizes may have looked passable on older small size tvs. They will not look very good on today's big screens.
Ulead DVD Movie Factory 6 Plus
By Ragamuffin in forum Authoring (DVD)Replies: 3Last Post: 6th Oct 2009, 12:22 -
Ulead DVD Movie Factory and Vista
By qpskfec in forum Authoring (DVD)Replies: 1Last Post: 4th Jan 2008, 14:08 -
Ulead DVD Movie Factory...
By mmitchell_houston in forum Authoring (VCD/SVCD)Replies: 225Last Post: 23rd Oct 2007, 10:59 -
By koberulz in forum Newbie / General discussionsReplies: 10Last Post: 26th Jun 2007, 07:14 -
Ulead DVD Movie Factory 5 Plus Help
By sootylfc in forum Authoring (DVD)Replies: 3Last Post: 21st May 2007, 18:20
