Hi,
I used VirtualDub with the following settings to convert a VCD to Divx avi:
Divx 4 Low Motion:
Keyframe every 10 seconds
Crispness - 100%
Bitrate - 364
MPEG Layer 3 for Audio:
128kbps, 44khz, 16Kbps
After this when I check the output file, the sound is terribly out of sync. Its ok in the beginning but screws up around the 4th or 5th minute.
Please help me solve this problem. Thanks.
Later,
Martin
Well I solved this problem. The Divx 5 bundle was the cause. I uninstalled it and it encodes in synch now.
But I have another problem. Whenever I encode I get a crackling noise in the divx avi that is created. Anyone knows how to fix that.
I know I can separate into wav and edit the wav. I mean can I do something so that the crackling noise isn't there in the first place.
PLEASE HELP
Thank you.
hardware needed to play divx via usb port
By julie_152 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 17th Feb 2010, 10:53 -
[ HELP NEEDED ] BD-ROM to BD-R 25 with BDRebuilder: how much CPU is needed?
By Tyrexionibus in forum Blu-ray RippingReplies: 1Last Post: 28th Oct 2009, 12:27 -
Divx to NTSC DVD: is Dgpulldown needed if Fps is 23.976?
By kalii2 in forum Video ConversionReplies: 4Last Post: 20th Jan 2008, 08:29 -
DivX file needed
By Tbag in forum ComputerReplies: 2Last Post: 25th Oct 2007, 16:35 -
Memory upgrade needed for TMPGENC DVD Author 3, advice needed
By Caned_and_Able in forum ComputerReplies: 8Last Post: 31st Jul 2007, 18:30
