...and I'm trying to normalize the audio as I have a total of 60 clips from 60 different sources so the audio levels are all over the place. I'm using PowerDirector 9 and I pulled all the wavs and followed this guide using Adobe Audition http://www.adobe.com/designcenter/audition/articles/aud15sdnormaliz.html but tbh the clips now sound like garbage. Is there any other way to do this where I wouldn't lose this much quality? Should I run different settings in Audition? Any help would be greatly appreciated.
Sound like garbage? From normalization? WHat was the format/bitrate of the original files and what did you save them to?
Provide a sample before and after. -
Maybe garbage wasnt the best word, I mean they are certainly listenable, but just not ideal. When I get home Ill upload some samples.
Lacie Cinema: Can't power device on using remote but will power on with USB
By truequant in forum Media Center PC / MediaCentersReplies: 1Last Post: 14th Nov 2011, 03:03 -
Building a Low Power Desktop...with Laptop like power?
By Moontrash in forum ComputerReplies: 31Last Post: 18th May 2010, 22:15 -
authoring x264 .mkv files for Power Hour DVD
By TraceBusta in forum Authoring (DVD)Replies: 1Last Post: 1st May 2009, 15:51 -
DVD Power Hour Project Help.
By GlockMasta in forum Authoring (DVD)Replies: 3Last Post: 1st May 2009, 06:23 -
Need advice on making dvd copies and making ISO files please.Thanks!
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 1Last Post: 17th Jan 2008, 12:03
