Hi!
I'm setting up a CentOS Server with FFmpeg to convert source FLV (and soon MP4/H264) videos to MP4/H264/AAC compatible mainly with iPhone and Android devices (and new devices that support H264/AAC) to be streamed using Wowza Streaming Server over 3G mobile networks.
Currently we do our video conversion on a Windows Machine with FFmpeg (using these builds: http://ffmpeg.arrozcru.org/) and the following command:
That command was done by a co-worker a couple years ago and its working fine on the tests I've done.Code:ffmpeg.exe -i source_video.flv -y -vcodec libx264 -s qvga -acodec libfaac -ab 96k -ac 2 -b 200K -threads 4 -flags +loop -cmp +chroma -partitions 0 -me_method epzs -subq 1 -trellis 0 -refs 1 -coder 0 -me_range 16 -g 300 -keyint_min 25 -sc_threshold 40 -i_qfactor 0.71 -maxrate 10M -bufsize 10M -rc_eq 'blurCplx^(1-qComp)' -qcomp 0.6 -qmin 10 -qmax 51 -qdiff 4 -level 30 target_video.mp4
However since I'm installing this new server with the latest version of FFmpeg, I wanted to know if I could optimize that command for better results in this Linux server with the latest FFmpeg.
I tried the above command on my new server and produced similar results as I used to produce in the Windows machine setup.
Here is the meta data from a sample video I produced using the above command on my new Linux setup.
Code:General Complete name : ffmpeg_test.mp4 Format : MPEG-4 Format profile : Base Media Codec ID : isom File size : 5.08 MiB Duration : 2mn 39s Overall bit rate : 268 Kbps Writing application : Lavf52.64.2 Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : Baseline@L3.0 Format settings, CABAC : No Format settings, ReFrames : 1 frame Codec ID : avc1 Codec ID/Info : Advanced Video Coding Duration : 2mn 39s Bit rate mode : Variable Bit rate : 200 Kbps Width : 320 pixels Height : 240 pixels Display aspect ratio : 4:3 Frame rate mode : Constant Frame rate : 30.000 fps Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.087 Stream size : 3.96 MiB (78%) Writing library : x264 core 107 Encoding settings : cabac=0 / ref=1 / deblock=1:0:0 / analyse=0x1:0 / me=dia / subme=1 / psy=1 / psy_rd=0.00:0.00 / mixed_ref=0 / me_range=16 / chroma_me=1 / trellis=0 / 8x8dct=0 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=0 / threads=4 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / constrained_intra=0 / bframes=0 / weightp=0 / keyint=300 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=abr / mbtree=1 / bitrate=200 / ratetol=20.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / vbv_maxrate=10000 / vbv_bufsize=10000 / ip_ratio=1.41 / aq=1:1.00 / nal_hrd=none Audio ID : 2 Format : AAC Format/Info : Advanced Audio Codec Format profile : LC Codec ID : 40 Duration : 2mn 39s Bit rate mode : Variable Bit rate : 55.8 Kbps Channel(s) : 2 channels Channel positions : Front: L R Sampling rate : 22.05 KHz Compression mode : Lossy Stream size : 1.06 MiB (21%)
What do you think?
Could that command be optimized for better results?
Thanks!
Results 1 to 1 of 1
Converting MOV videos to DVD from iPhone 4S
By jpifer_nc in forum Video ConversionReplies: 4Last Post: 11th Dec 2011, 13:23 -
MP4 Subtitle Question; Of Android(Tablet/Phone)/PS3/Iphone/Ipad Devices
By WearWolf in forum SubtitleReplies: 6Last Post: 31st Oct 2011, 02:54 -
best video output format for youtube, iphone, android?
By videdit in forum Video ConversionReplies: 2Last Post: 25th Oct 2011, 11:34 -
converting for ipad using ffmpeg 0.8
By richiedood in forum Video ConversionReplies: 0Last Post: 1st Jul 2011, 19:03 -
run mp4 on iphone and android-smartphones???
By rashomon in forum Video ConversionReplies: 2Last Post: 1st Aug 2010, 08:31
