Before you tell me: yes, I have searched for this on google and even this website but I did not find any solutions that worked for me and that I understood. I have the 'K-Lite Mega Codec Pack 7.0.0' and the MPC version that comes with it 1.5.0.2827 and I have Windows 7 64-bit. When playing an .mkv that has two audio tracks it only shows the first option. I am able to use VLC to change tracks but I prefer MPC, in fact I dislike VLC greatly. So, is anyone able to help me?
Try reinstall haali media splitter and disable the mpchc builtin audio switcher(View->Options->Internal filters->Audio switcher).
Then be sure to check both under Play->Audio and Navigate->Audio Language and see if can you can change tracks.
Distorted audio in Media Player Classic
By taptchan in forum Software PlayingReplies: 4Last Post: 6th Mar 2023, 11:35 -
Media Player Classic 6.4.9.1 to play multiple videos?
By Throb1231 in forum Software PlayingReplies: 6Last Post: 1st Aug 2016, 19:49 -
Media Player Classic HC not recognizing both audio tracks
By lordhutt in forum ComputerReplies: 2Last Post: 2nd Apr 2010, 19:04 -
No audio with Media Player Classic
By Compultion in forum Software PlayingReplies: 1Last Post: 4th May 2009, 03:51 -
Media Player Classic audio playback problem
By qpskfec in forum Software PlayingReplies: 2Last Post: 3rd Dec 2008, 14:09
