Hi Bought this SDV camcorder. It records high quality video on sdhc cards.. The only output is a cable that plugs into the camera uses a USB into my PC to import video into a included software called EVERIO MEDIABROWSER. I can then burn to a DVD. But i can only select desired clips, no other editing.
My card reader shows three folders EXTMOV PRIVATE SD_VIDEO What software or program can I edit my movies using avi files? And what folder do i use fron the card?
Thanks Bob
Results 1 to 1 of 1
How to edit uncooperative .MOV files into a movie?
By WaWMoose in forum Newbie / General discussionsReplies: 16Last Post: 10th May 2015, 15:33 -
Help!!! .mov files from Jvc hd200 and fcp5? is it possible?!!
By Chris Yule in forum EditingReplies: 3Last Post: 22nd Mar 2010, 13:46 -
Can not import mov files into AE cs4
By moprh1 in forum Video ConversionReplies: 0Last Post: 30th Dec 2009, 22:06 -
What program can import and edit MJPEG files?
By yic17 in forum EditingReplies: 4Last Post: 26th Dec 2009, 13:32 -
MOV files, cant open to edit/convert
By haggisuk in forum Video ConversionReplies: 3Last Post: 12th Oct 2009, 11:16
