    Jul 2002
    We have a pc running windows xp sp3 that has several copies of the MS c++ redistributable program. Is it necessary to keep them all or can we delete some of them?
  2. Banned
    Nov 2005
    the visual c++ entries you see are run time libraries needed by the program that installed them, i.e. they are dependencies that are required for the app to work properly. just because they are all listed as ms c++ redistributable doesn't mean that are all the same library.
    on a related note, i personally consider it an extremely half assed way pf programming when an app requires the visual c++ run time libraries to be installed in order for the app to work; the programmer should either statically link all the required libraries so they are part of the executable or just include the required dll's with his app.
  3. DECEASED
    Jun 2009
    Heaven
    SFAIK, there are three "well-known" Visual C++ Redistributable Packages:
    VS 2005 ( and its respective "service pack" )
    VS 2008 ( and a recommended "security patch" )
    VS 2010
    And all of them are named... * vcredist.exe *.
    Lack of imagination, or just intellectual lazyness ?
    I'd rather see a single, regularly-updatable,
    compressed, and 100% backward-compatible, MSVCRT.DLL.
    I know, I keep dreaming.
  4. VH Wanderer Ai Haibara's Avatar
    Jan 2006
    Somewhere on VideoHelp...
    What about a version of .NET that isn't more or less completely incompatible with every version that preceeded it?
