Results 1 to 23 of 23
  1. I cant play a movie as I got this error Windows Media Video 9 (WMV3) codec is not installed on your computer.
    But isnt that old as I have WMP 11
    What is the exact error? Try google it.
  3. VH Wanderer Ai Haibara's Avatar
    Jan 2006
    Somewhere on VideoHelp...
    IIRC, not all of the Windows Media codecs are installed, by default. Have you tried playing the video in Windows Media Player? I believe it's supposed to automatically download and install certain codecs, if they're required by the video (and provided by Microsoft, which the WM codecs should be). I can't remember if WMP has a setting that would prevent it from doing that, though.
    I believe Microsoft also has a package or two to install all of the Windows Media codec support, though I don't remember where it is on their site or what it's called, offhand. There's also ffdshow, but you'd have to manually enable the codec support in the decoders - and I'd recommend installing the Microsoft support over ffdshow for the WM codecs at this time, anyway.
  4. Lone soldier Cauptain's Avatar
    Jan 2006
    Brazil
    Ai Haibara post is correct. Try it:
    Claudio
  5. Originally Posted by natty View Post
    I have and get this
    http://www.google.co.uk/search?sourceid=navclient&ie=UTF-8&rlz=1T4ADFA_enGB400GB401&q=...your+computer.
    I dont understand this above whats MS support
    I wouldnt have a clue how to do this anyway in ffshow
    this is what it says
  6. I'm a MEGA Super Moderator Baldrick's Avatar
    I deleted your other thread. Please wait some years until you bump your thread and never make a new thread.
    Mar 2008
    There is a setting in WMP tools/options/player tab - download codec automatically.
    If this is checked, Microsoft should download the codec and install it for you, since it is their codec and their player.
  8. Originally Posted by davexnet View Post
    well this is what I have in WMP but it hasnt updated
    http://s1.bild.me/bilder/110211/3141652wmp.jpg
    but it says here I have got wmv3
    http://s1.bild.me/bilder/110211/7465142codecs.jpg
    Huh LOL dont you mean wait a while not years god, sorry baldrick but I wasnt getting no replies
  9. VH Wanderer Ai Haibara's Avatar
    Jan 2006
    Try downloading the wm9codecs installer from here, installing it, and see if that helps. If not, we'll try enabling the Windows Media support in ffdshow (you have ffdshow installed, right? ).
    Edit: You might also want to install MediaInfo, and use that instead of GSpot for information on video containers other than AVI/.divx/MPEG - GSpot's support for other containers is rather work-in-progress/incomplete, and may not list everything (or even work correctly).
  10. Originally Posted by Ai Haibara View Post
    Hi I already tried wm9codecs installer and get this below
    http://s1.bild.me/bilder/110211/9906441wmperror.jpg
    yes i have ffdshow installed
  11. If you're running 64 bit Windows there are additional complications. 32 bit and 64 bit programs need 32 bit and 64 bit codecs, respectively.
    I am running 32 bit windows xp
    Mar 2008
    If you're running XP, uninstall WMP 10/11 (it will revert to earlier version) .
    Reboot and reinstall WMP 11.
  14. Originally Posted by davexnet View Post
    well its not even listed in add/remove but will uninstall it manually
    EDIT: Well so much for uninstalling it as there is no uninstaller how do I uninstall
    Mar 2008
    In my XP, it is listed as Windows Media Player 11. Are yo sure it's not there?
    I looked in the registry at the uninstall section and the command they use to uninstall is this:
    "F:\Program Files\Windows Media Player\Setup_wm.exe" /Uninstall"
    Do not delete any files manually.
  16. Originally Posted by davexnet View Post
    its not listed in add/remove at all so cant make this out
  17. DECEASED
    Jun 2009
    Heaven
    Have you already installed this one ?
    https://www.videohelp.com/tools/WMV9_VCM
    That's too vague.
  18. Originally Posted by El Heggunte View Post
    That's too vague.
    I just installed the above link and tried movie but I still get same error it went to WMP 11 and said codec error use WMP but it is using WMP dont make sense to me. also on the above link when I installed I never got this as there isnt no .exe to run it also what do you mean by thats too vague
    http://s1.bild.me/bilder/110211/1025482wmp3.jpg
    can anyone help on this please
    I DONT SEEM TO BE GETTING ANYMORE REPLIES PLEASE SOMEONE HELP
    Feb 2004
    Australia
    Once media player has been updated past version 10 the system can only revert back to previous version if system restore point is available.
    A quick look at the snapshot from gspot you provided tell's me instantly that this file will never play.
    In the container panel is says
    "Note: 691 mb unneeded bytes at end of file" from a total of 691mb original
    The file is fake which meant you wasted time downloading it in the first place.
  20. I'm a MEGA Super Moderator Baldrick's Avatar
    BUMP your thread instead of creating new threads.
  21. Originally Posted by Bjs View Post
    ok thanks for replying
  22. Originally Posted by Baldrick View Post
    Well I find if I bump a Thread no one replies as its an old post
