I'm having a heck of a time trying to find a muslin type of backdrop in a deep rich burgudy or merlot color like this:
http://www.cardinalwinesandspirits.com/Assets/laWineGlass.gif
Does anyone here know of one in existence? Thanks!
Huh?
You want a print of a wineglass as a backdrop?Want my help? Ask here! (not via PM!)
http://www.kiva.org/about -
I meant an actual, physical backdrop, not using a green screen with digital background....
Go to Joann's or some other similar fabric store.
My mom and sister both sewed so I spent a lot of time in fabric stores. The problem with buying pre-dyed fabrics is that most will only be available in widths that are too narrow for a large backdrop. However, most large fabric stores have bleached and unbleached muslin, cotton sheeting or similar all-cotton fabrics in larger rolls. Either Joann Fabrics, Hancock Fabrics or Michael's should also have dyes that work well with all-cotton fabric. If there is nothing close, Rit has a color mixing chart. Mix up a little and do a test with a small piece of your fabric until you acheive the desired shade.
Where to find moonscape backdrop video for chromakey?
By lboiv001 in forum Newbie / General discussionsReplies: 1Last Post: 19th Sep 2010, 07:04 -
You too could get RICH!!!
By Noahtuck in forum Off topicReplies: 0Last Post: 24th Sep 2009, 12:07 -
Buying a "backdrop kit"...?
By Bansaw in forum Newbie / General discussionsReplies: 4Last Post: 27th Apr 2009, 14:24 -
anyone knows how to make this (example)
By pike8 in forum EditingReplies: 6Last Post: 18th Feb 2008, 17:21 -
How do I make my Samsung R150 recorder region free? I have the code to make
By charpee in forum DVD & Blu-ray RecordersReplies: 2Last Post: 26th Jan 2008, 07:10
