Where can I get the raw output from AVCHD Camcorders and HD mpeg too. I have been to several web sites and they all were lacking. I want to test the clips against software to see how functional they are. Today, unless you want to spend hundreds of dollars for software, there are various problems with software $100 or less. I would like to test the magnitude of these problems. As new hardware and software are ahead of the above alluded to software($100), before purchase testing is mandatory. Your assistance will be appreciated. I am looking for the pragmatic experimental FACTS!
I usually search for the camera model and "download" or "sample". Something usually turns up. Steve's Digicams usually has a video file or two in their reviews.
http://www.steves-digicams.com/ -
What kind of $100 software are you looking to test?
Your listed computer and video card are not up to the AVCHD task. Figure a Core2 quad or better and a "Purevideo HD"* NVidia card for hardware AVC decode.
For AVCHD editing, a good choice is Vegas Movie Studio Platinum 10. If you shop around you can get it for $70 or less.
* "AVIVO HD" for ATIRecommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
I am fully aware of the fact of my computer's capability. However, I can process small clips to test software and various small things. I will not upgrade to Sandy Bridge until I know what software can do knowing full well it's another world with Sandy Bridge. Though, I grant you the scope is narrow, still I can test some things.
Export HDV clips to SD clips from Premiere Pro CS3
By foochuck in forum EditingReplies: 10Last Post: 8th Jun 2010, 17:03 -
Do anyone know how to combine video clips into one video File ?
By blkwht240 in forum Newbie / General discussionsReplies: 11Last Post: 7th Feb 2010, 13:57 -
Windows Movie Maker. Blank video when splitting, trimming video clips
By rlarden in forum EditingReplies: 2Last Post: 3rd Jul 2009, 06:23 -
need assistance getting video clips
By Olshan in forum Newbie / General discussionsReplies: 3Last Post: 21st Sep 2007, 11:50 -
Want to take 0.25 sec video clips from a 10 minute video
By videocheez in forum EditingReplies: 2Last Post: 2nd Jun 2007, 19:36
