i just bought for 40 odd bucks
it's the lightcribe version
is it any good ? the same as the non-lightcribe version ?
i have no intention to use the lightscibe feature , was the only ide left
i haven't installed it yet
It should be OK but you paid too much.
http://www.newegg.com/Product/Product.aspx?Item=N82E16827151175
Newegg has plenty of IDE burners available for about $20 US. I'm sure that shipping to Canada would not be so expensive as to exceed what you paid.
You are wise to avoid Lightscribe as using it will shorten the life of the burner. I used to use Lightscribe and it did that to all 3 of the burners I bought.
LG GH22LP20 lightscribe problem
By RC_cat in forum DVD & Blu-ray WritersReplies: 5Last Post: 16th Jun 2009, 09:20 -
LG GH22LP20 16X won't burn at more than 2X
By BeyondInvisible in forum DVD & Blu-ray RecordersReplies: 2Last Post: 3rd Feb 2009, 14:55 -
dvd writer help
By Stephb in forum DVD RippingReplies: 2Last Post: 2nd Feb 2009, 16:38 -
dvd / cd writer
By bill gailer in forum DVD & Blu-ray RecordersReplies: 6Last Post: 23rd Jan 2009, 22:18 -
LG GH22LP20 problem
By Gyongyi in forum DVD & Blu-ray WritersReplies: 3Last Post: 17th Sep 2008, 13:25
