Hiya
I have Studio 14 HD and a new Panasonic SD60 Camcorder
Pinnacle can see my files and imports them, but when I drag them to the timeline nothing happens. They also won't play either within Pinnacle
I downloaded Vegas 10 Pro Trial and they work perfectly in there so I assume I don't have a codec issue.
Now do I need to convert or am I doing something wrong ?
If I do need to convert, what do I use and to what file type ?
Many thanks
Paul
Results 1 to 9 of 9
To remux your videos from one container to another. One of the output choices (TS, M2TS, Blu-ray, AVCHD) may work with Pinnacle Studio. You may also need an h.264 decoder. You can use ffdshow for that.
Did you activate it? Their website says AVCHD is supported but * Requires free product activation via the Internet.
Vegas has it's own internal decoder for AVCHD; - most NLE's don't use system installed codecs, except for some AVI container formats
You could also ask at their forum , it's got a bad reputation around here as junk software
Sample Blu ray, m2ts, mts files
By pepegot1 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 8th Jan 2011, 16:15 -
Any good utility to join m2ts (or MTS) from AVCHD camcorders?
By sebaz in forum EditingReplies: 4Last Post: 17th Jan 2010, 12:10 -
Workflow Help with MTS/M2TS --> WMV and AVI.MKV --- (long, Canon HG10 sr
By RonUSMC in forum Video ConversionReplies: 8Last Post: 24th Jul 2009, 04:49 -
mts or m2ts playback via Media Center x64 Vista possible? queuing them too?
By markm75 in forum Media Center PC / MediaCentersReplies: 4Last Post: 10th Nov 2008, 10:07 -
avchd m2ts/mts editing stats and observations.. and some questions linger..
By markm75 in forum Authoring (Blu-ray)Replies: 8Last Post: 24th Jul 2008, 00:02
