Hi!
Im going to send a screening copy to a film festival. They want the following format:
Right now I got this:MOV-Container, PAL(SD)-resolution, DV-Codec, output field: bottom
first, 48 KHZ, 16 Bit
when I resize the file to get it into SD PAL shall I then use the resize tab (on quicktime settings) and choose:Frame size:
1440x1080
Vid Rate
25 fps
Compressor
HDV1080i50
Pixel Aspect:
HD (1440x1080)
Audio format
16-bit integer
Audio Rate
48 Khz
correct?framesize: 720x576
Pixel Aspect: PAL CCIR601 (16:9)
which settings shall I use in compressor to get the best quality?
thanks
perik
Results 1 to 1 of 1
Changing Container from MOV to MP4 in bulk?
By anonymous99 in forum Video ConversionReplies: 13Last Post: 28th May 2012, 10:24 -
Quicktime MOV to WMV3 in AVI Container
By kangmuchi82 in forum Video ConversionReplies: 5Last Post: 28th Sep 2011, 00:05 -
unknown codec, mov container
By jlz901 in forum Video ConversionReplies: 4Last Post: 1st Apr 2009, 20:25 -
Using Compressor 3.0 Pal to Ntsc???
By funkymix in forum MacReplies: 9Last Post: 18th Mar 2009, 09:26 -
PHP code used to generate code for Avysinth join mov and avi files
By lindylex in forum User guidesReplies: 0Last Post: 19th Sep 2008, 04:37
