I have 2 dvd recorders, one is panasonic, and the other is Phillips. Both seem to work fine. My problem is when I set them to record from a digital channel, SOMETIMES the recording comes out blank. The wording on the screen suggest I recorded the right channel at the right time, but only blackness shows up. This does not happen all the time, just once in a while. I am in the Cleveland Ohio area and the prob usually happens on ch 3.1, but has occured on 19.1 also. Anyone know what is causing this ?
	Premium channels ?. Maybe the tv sends out a copy-protection signal.
	Perhaps the DVD recorder's tuner is receiving a signal that is too weak to tune properly. I think copy-protected programming would generate a message telling you why these programs could not be recorded.
	More info required:
 Are you recording off air ATSC or from a cable/sat box? If off air, there SHOULD be no copy protection but local channels often screw this up and set a copy protection bit by mistake. So far Congress hasn't authorized this. Cable companies can do what they want for other than broadcast pass through. For broadcast they are prohibited from adding copy protection or encryption*.
 * It gets more complicated than that depending on the status of the local station as "must carry", "retransmission consent" or PBS. Each has separate rules.Recommends: Kiva.org - Loans that change lives.
 http://www.kiva.org/about
	My Philips DVD Recorder does the same thing on some digital cable channels. IIRC, it is a known issue and has been discussed at avsforum. I don't know about the Panasonic, though...do they both fail on the same channels? Life is better when you focus on the signals instead of the noise.
	Sounds like the Broadscast Flag was set:
 http://en.wikipedia.org/wiki/Broadcast_flagThey that give up essential liberty to obtain a little temporary safety deserve neither liberty or safety.
 --Benjamin Franklin
  software for recording all channels in the same transponderBy WuxiIxuw in forum Capturing and VCRReplies: 13Last Post: 18th Aug 2012, 15:02
  Digital to analog channelsBy ady57590 in forum Video ConversionReplies: 2Last Post: 8th Nov 2011, 08:19
  Recording Movies From Premium ChannelsBy mykicks in forum DVD & Blu-ray RecordersReplies: 10Last Post: 25th Oct 2010, 12:14
  Recording multiple TV channels at the same timeBy Namocol in forum Media Center PC / MediaCentersReplies: 14Last Post: 16th Nov 2008, 08:56
  Automatically recording SopCast channelsBy ThePMonkey in forum Video Streaming DownloadingReplies: 1Last Post: 22nd Apr 2008, 22:27
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
			 Visit Homepage
				Visit Homepage
