  1. Member Antares's Avatar
    Feb 2011
    Belgium
    Hello, I'm back again. I was recently active on the thread "Pulling data from unfinalized disk".
    This problem is solved thanks to you.
    But unfortunately I have a new issue now.
    I have this other more recent TV recording on videotape. You may ask yourself : more recent and on videotape ????? Well, that's because my dvd recorder was broken at the time and the friend who then recorded it for me also had a problem with his dvd recorder and he put it on videotape.
    I'm goin to call this recordering : CCrack. So that you know which recording I'm talking about further is this thread.
    Now just a few days ago a friend burned Ccrack to DVD for me (on a DVD+R disk).
    But when I play it on my computer the quality is bad (but perhaps the videotape itself sucks).
    On my DVD player I cannot play it at all.
    So my aim was to demux it and try to edit t.i. improve the video (there are many horizontal lines (interlace ?) and the audio part which is not loud enough and then put it on my USB-stick to play on TV.
    So I tried the same procedure as I did for the unfinalized disk.
    I made a tao.file first and then tried to demux it.
    But... I can only demux the video part. The audio part doesn't work.
    The difference now is that the audio part seems to be another format.
    When I open the tao.file of Ccrack in Vobedit I see in the left pane that the audio part is shown as
    [Audio MPEG Stream CH0], 07ec and sometimes also [Audio MPEG Stream CH0],04cc.
    When I try to demux I can't find the right way to do it.
    On the unfinalized disk the audio part in the tao.file was listed as AC3.
    What bothers me also is, that when I play the tao.file of Ccrack there seems already to be a synchronization problem which isn't there on the DVD itself.
    Do I now have to work otherwise, instead of making a tao.file first ?
    If there is extra information that you need, please ask me and I will try to provide it.
    I look forward to your replies and I already thank you for the effort you all put in to this. Respect !!
    A humble Belgian girl.
    Aug 2006
    What files and folders do you see on this DVD-R disc. What does MediaInfo report about it?
  3. Member Antares's Avatar
    Feb 2011
    Belgium
    Hello ! Thanks for replying.
    The DVD contains 2 TV-shows.
    In Mediainfo the DVD disk shows the following:
    a) Video_RM
    General
    Complete name : D:\VIDEO_RM\DVD_REC.USR
    File size : 32.0 KiB
    General
    Complete name : D:\VIDEO_RM\PVR_TEMP.USR
    Format : MPEG-PS
    File size : 64.0 KiB
    Duration : 40ms
    Overall bit rate : 13.1 Mbps
    Writing library : MTK MT8105
    Video
    Format : MPEG Video
    Format version : Version 2
    Format profile : Main@Main
    Format settings, BVOP : No
    Format settings, Matrix : Default
    Format settings, GOP : N=1
    Duration : 40ms
    Bit rate mode : Variable
    Bit rate : 2 000 Kbps
    Width : 352 pixels
    Height : 288 pixels
    Display aspect ratio : 4:3
    Frame rate : 25.000 fps
    Standard : PAL
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Progressive
    Compression mode : Lossy
    Bits/(Pixel*Frame) : 0.789
    Stream size : 9.77 KiB (15%)
    Menu
    General
    Complete name : D:\VIDEO_RM\VIDEO_RM.BUP
    General
    Complete name : D:\VIDEO_RM\VIDEO_RM.DAT
    File size : 1.00 MiB
    General
    Complete name : D:\VIDEO_RM\VIDEO_RM.IFO
    b) Video_TS
    General
    Complete name : D:\VIDEO_TS\VIDEO_TS.BUP
    Format : DVD Video
    Format profile : Menu
    File size : 12.0 KiB
    Video
    Format : MPEG Video
    Width : 720 pixels
    Height : 576 pixels
    Standard : PAL
    Text
    Format : RLE
    Format/Info : Run-length encoding
    Bit depth : 2 bits
    General
    Complete name : D:\VIDEO_TS\VIDEO_TS.IFO
    Format : DVD Video
    Video
    Format : MPEG Video
    Width : 720 pixels
    Height : 576 pixels
    Standard : PAL
    Text
    Format : RLE
    Bit depth : 2 bits
    General
    Complete name : D:\VIDEO_TS\VIDEO_TS.VOB
    Format : MPEG-PS
    Duration : 40ms
    Video
    Format : MPEG Video
    Duration : 40ms
    Width : 720 pixels
    Height : 576 pixels
    Standard : PAL
    Color space : YUV
    Bit depth : 8 bits
    Scan type : Interlaced
    Scan order : Top Field First
    Bits/(Pixel*Frame) : 0.193
    Text
    ID : 189 (0xBD)-32 (0x20)
    Format : RLE
    Muxing mode : DVD-Video
    Menu
    General
    Complete name : D:\VIDEO_TS\VTS_01_0.BUP
    Format : DVD Video
    Format profile : Program
    File size : 46.0 KiB
    Duration : 31mn 38s
    Overall bit rate : 198 bps
    Video
    Format : MPEG Video
    Duration : 31mn 38s
    Width : 720 pixels
    Height : 576 pixels
    Standard : PAL
    Audio
    Format : MPEG Audio
    Format profile : Version 1
    Duration : 31mn 38s
    Channel(s) : 2 channels
    Sampling rate : 48.0 KHz
    Text
    Format : RLE
    Bit depth : 2 bits
    Menu #1
    Duration : 31mn 38s
    00:00:00.000 : Chapter 1
    00:05:00.400 : Chapter 2
    00:10:00.400 : Chapter 3
    00:15:00.400 : Chapter 4
    00:20:00.400 : Chapter 5
    00:25:00.400 : Chapter 6
    00:30:00.400 : Chapter 7
    List (Audio) : 0
    List (Subtitles 4/3) : 0
    List (Subtitles Wide) : 0
    List (Subtitles Letterbox) : 0
    List (Subtitles Pan&Scan) : 0
    Menu #2
    Duration : 23mn 13s
    00:00:04.720 : Chapter 2
    00:00:09.440 : Chapter 3
    00:00:14.160 : Chapter 4
    00:00:18.880 : Chapter 5
    List (Audio) : 0
    General
    Complete name : D:\VIDEO_TS\VTS_01_0.IFO
    Format : DVD Video
    Duration : 31mn 38s
    Video
    Format : MPEG Video
    Duration : 31mn 38s
    Width : 720 pixels
    Height : 576 pixels
    Standard : PAL
    Audio
    Format : MPEG Audio
    Duration : 31mn 38s
    Text
    Format : RLE
    Bit depth : 2 bits
    Menu #1
    Duration : 31mn 38s
    List (Audio) : 0
    Menu #2
    Duration : 23mn 13s
    List (Audio) : 0
    General
    Complete name : D:\VIDEO_TS\VTS_01_1.VOB
    Format : MPEG-PS
    File size : 1 020 MiB
    Duration : 28mn 45s
    Overall bit rate : 4 960 Kbps
    Video
    Format : MPEG Video
    Format settings, BVOP : Yes
    Format settings, GOP : M=3, N=12
    Duration : 28mn 45s
    Bit rate : 4 620 Kbps
    Width : 720 pixels
    Height : 576 pixels
    Standard : PAL
    Color space : YUV
    Bit depth : 8 bits
    Bits/(Pixel*Frame) : 0.446
    Stream size : 947 MiB (93%)
    Audio
    Format : MPEG Audio
    Format version : Version 1
    Format profile : Layer 2
    Mode extension : MS Stereo
    Duration : 28mn 45s
    Bit rate mode : Constant
    Bit rate : 256 Kbps
    Stream size : 52.6 MiB (5%)
    Menu
    General
    Complete name : D:\VIDEO_TS\VTS_01_2.VOB
    Format : MPEG-PS
    File size : 942 MiB
    Overall bit rate : 1 839 bps
    Video
    Format : MPEG Video
    Nominal bit rate : 4 620 Kbps
    Width : 720 pixels
    Height : 576 pixels
    Standard : PAL
    Color space : YUV
    Bit depth : 8 bits
    Audio
    Format : MPEG Audio
    Bit rate : 256 Kbps
    Delay relative to video : -94ms
    Stream size : 128 GiB
    Menu
    I hope this is helpfull ?
    Aug 2006
    The VIDEO_RM folder may be the reason why your disk won't play. See http://www.afterdawn.com/glossary/term.cfm/video_rm The audio and video characteristics shown by Mediainfo look normal.
    Use VOB2MPG on the VIDEO_TS folder. It will join the VOBs and put them in an .mpg container. You can edit the .mpg with AviDemux. Use File-> Open to import the .mpg. Set both "Video" and "Audio" to "Copy" and set "Format" to "MPEG-PS (A+V)". If the audio and video are not synchronized when you play the .mpg, check the "Shift"box, and enter a positive or negative number of miliseconds to adjust the audio timing. Use the buttons that have 2 arrows/triangles on them to find keyframes. Click "A" at the start and "B" at the end of the section to be removed, then press the Delete key on your keyboard. File->Save->Save Video will export an edited .mpg file. You can put your edited .mpg file on a USB stick at this point.
    Sometimes the interlacing lines are present because a software video player does not use a good de-interlacer, and in that case the video will look better on your TV. ...but sometimes they are a capture artifact. Getting a good-looking VHS to DVD transfer can be difficult. I don't do many VHS to DVD transfers, and have little expertise in the area of correcting poor-quality transfers. I do know that fixing some common problems with VHS to DVD transfers after doing the capture is impossible, and learning how to fix the others requires a lot of self-education and experimentation.
  5. Member Antares's Avatar
    Feb 2011
    Belgium
    Thanks for the reply. I'll keep you informed !
  6. Member Antares's Avatar
    Feb 2011
    Belgium
    First I made some mistakes using Vob2mpg.
    I started from the tao.file which was totally wrong. I encountered several problems including a backdoor trojan horse which was quarantined by my NIS.
    And of course, you meant I had to start from the DVD itself.
    OK. I had to select IFO mode (VOBSET mode did not work).
    I got 6 titles and 7 chapters.
    I selected all of them and made it so.
    Then I had a mpg.file of the recording (me happy) and I used Mpg2Cut to isolate the wanted show.
    Now I want to improve the sound (there's a kind of scratch in it, somewhat like paper being crumpled) and the image which is somewhat blurry.
    Which editing program do you recommend for this ?
    Aug 2006
    I'm glad you have a .mpg file now.
    Correcting a blurry picture is probably not possible.
    I don't have experience fixing audio problems. Someone else will have to help you with that. It probably won't be easy to remove the crackling noise without replacing it with silence. Making the video louder is likely to be easier.
  8. Member Antares's Avatar
    Feb 2011
    Belgium
    OK hopefully someone else will pick up from here ?
    Thanks again for all the help !!
    That's worth three kisses !! (= custom here in Belgium)
