Hello all. I need some input on what video player will work for the videos I have created. The videos are created with an open source program in Linux called Motion. They are encoded with FFmpeg in mpeg-4 format. There is no choice to convert these videos to a better format such as mp4, which most media players for websites use that I have found.
The one media player I have found that halfway works is Real Player which gives me an error "This movie is not optimized for progressive playback." I do not have the exact error code and frankly, I don't care if there are other video player options. Quick Time was also tried, which resulted in a green screen. I'm not looking for diagnosis of these players, just an option that will work with video and sound.
My main question: What video player will work with the video information provided below by FFmpeg?
-MooneyCode:FFmpeg version git-N-28545-g038566a, Copyright (c) 2000-2011 the FFmpeg developers built on Mar 21 2011 13:55:25 with gcc 4.4.5 configuration: --enable-gpl --enable-version3 --enable-nonfree --enable-postproc --enable-libfaac --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libtheora --enable-libvorbis --enable-libvpx --enable-libx264 --enable-libxvid --enable-x11grab libavutil 50. 40. 0 / 50. 40. 0 libavcodec 52.114. 0 / 52.114. 0 libavformat 52.103. 0 / 52.103. 0 libavdevice 52. 3. 0 / 52. 3. 0 libavfilter 1. 76. 0 / 1. 76. 0 libswscale 0. 12. 0 / 0. 12. 0 libpostproc 51. 2. 0 / 51. 2. 0 Input #0, avi, from '/od/2011-03-27-03-00-17.mp4': Metadata: encoder : MEncoder VERSION Duration: 00:01:03.50, start: 0.000000, bitrate: 212 kb/s Stream #0.0: Video: mpeg4, yuv420p, 640x480 [PAR 1:1 DAR 4:3], 30 tbr, 30 tbn, 30 tbc Stream #0.1: Audio: mp2, 44100 Hz, mono, s16, 64 kb/s At least one output file must be specified crimsonsecurity@thelookingglass:~$ ffmpeg -i /mv/32_day-03-29-2011_time-15-48-45.mp4 FFmpeg version git-N-28545-g038566a, Copyright (c) 2000-2011 the FFmpeg developers built on Mar 21 2011 13:55:25 with gcc 4.4.5 configuration: --enable-gpl --enable-version3 --enable-nonfree --enable-postproc --enable-libfaac --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libtheora --enable-libvorbis --enable-libvpx --enable-libx264 --enable-libxvid --enable-x11grab libavutil 50. 40. 0 / 50. 40. 0 libavcodec 52.114. 0 / 52.114. 0 libavformat 52.103. 0 / 52.103. 0 libavdevice 52. 3. 0 / 52. 3. 0 libavfilter 1. 76. 0 / 1. 76. 0 libswscale 0. 12. 0 / 0. 12. 0 libpostproc 51. 2. 0 / 51. 2. 0 Input #0, mov,mp4,m4a,3gp,3g2,mj2, from '/mv/32_day-03-29-2011_time-15-48-45.mp4': Metadata: major_brand : isom minor_version : 512 compatible_brands: isomiso2mp41 creation_time : 1970-01-01 00:00:00 encoder : Lavf52.103.0 Duration: 00:02:02.50, start: 0.000000, bitrate: 1310 kb/s Stream #0.0(und): Video: mpeg4, yuv420p, 640x480 [PAR 1:1 DAR 4:3], 1309 kb/s, 12 fps, 12 tbr, 12 tbn, 12 tbc Metadata: creation_time : 1970-01-01 00:00:00
Probably only with the vlc media player browser plugin.
Thanks. Do you know any helpful links other than the Video LAN Forums? I will have to try out some example code later tonight.
No, as stated in my first post, editing is not an option. It takes up too much CPU time. The video cannot change formats.
find another program to create your videos or learn how to change the specs. especially the audio, make it aac.
Thanks for the input aedipuss, I would love to change the specs. In order to do this, I would have to dig through the source of Motion for Linux, recompile it, and hope that it records correctly. This has crossed my mind.
Baldrick: I have found an example of using the VLC plugin but my buttons do not function correctly. The videos do play with autoplay set to yes. Could you lend a helping hand? My examples are located at: http://crimsonsecurity.dyndns.org/vlcmedia.html
Code:<h1>Demo of VLC mozilla plugin - Example 1</h1> <embed type="application/x-vlc-plugin" name="video1" autoplay="yes" loop="yes" width="400" height="300" target="/mv/02_day-03-29-2011_time-19-12-25.mp4" /> <br /> <a href="javascript:;" onclick='document.video1.play()'>Play video1</a> <a href="javascript:;" onclick='document.video1.pause()'>Pause video1</a> <a href="javascript:;" onclick='document.video1.stop()'>Stop video1</a> <a href="javascript:;" onclick='document.video1.fullscreen()'>Fullscreen</a>
Need Sony Vegas to Flash video for webpage help...
By liberty610 in forum Video ConversionReplies: 3Last Post: 15th Jan 2011, 07:55 -
Uploading a video on Amazon s3, How to embed it in the Webpage?
By Entry in forum Newbie / General discussionsReplies: 5Last Post: 26th Nov 2010, 19:09 -
No time shown in flv movies in VLC player or webpage
By RobRocket in forum Video ConversionReplies: 3Last Post: 19th Aug 2009, 05:39 -
New Video Editing Webpage
By Poisoned in forum Newbie / General discussionsReplies: 3Last Post: 2nd Feb 2008, 03:37 -
Video file coming up white box on webpage
By KameronK in forum Newbie / General discussionsReplies: 4Last Post: 10th Aug 2007, 09:24
