Results 1 to 12 of 12
    Jun 2010
    U.S.A.
    How do you change the Video Resolution in this program for AVI Xvid ?
  2. What version are you using 5x or 6x ?, I believe in version 6 you:
    Jun 2010
    U.S.A.
    The one I have is 5.10. Where do you find Version 6 ?
  4. Homepage - http://winnydows.com/#Downloads?XviD4PSP%206 (Must have silverlight installed)
    Under the tools section - https://www.videohelp.com/tools/XviD4PSP
    Daily builds are updated more frequently and v6 has less filters but is getting and will be better.
    Jun 2010
    U.S.A.
    Okay will try
    Jun 2010
    U.S.A.
    How do I set Target File Size ?
    Jun 2010
    U.S.A.
    Bump
  8. I'm a MEGA Super Moderator Baldrick's Avatar
    Please wait some DAYS before you bump.
  9. There's no two pass as of yet.
    Jun 2010
    U.S.A.
    5.10 let me pick Target File Size but I could not find any Video Resolution settings. Seems like a step down
  11. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    In version 5 you will find the resolution options in the video menu. I can't remember exactly where. I have given up on Xvid4PSP. Version 5.x started getting pretty flakey, then version 6 came out missing lots of the most useful features from version 5. In the meantime, XmediaRecode came along and pushed them both off my harddrive.
    Read my blog here.
