Hi all!
I'm capturing raw data from old VHS tapes with a Pinnacle card and then attempt to re-encode that, so, it takes less space. My aim is to get size efficient avi files.
However, my regular settings with VirtualDub that I use with PVR recordings won't work for this raw data -- the file size remains large despite re-encoding. I use 1800 kbps XviD (768x576) and 128 kbps LAME mp3, and I can't make 1 hour 20 minute video weigh less than 3,6GB. I'm not the most skilled encoder, but that's bad even for me. I also noticed that all the frames in the created avi are key frames. Maybe that's causing the size bloat?
What information do you need to resolve my issue?
Results 1 to 9 of 9
What xvid settings are you using? Profile level, Encoding type, etc?
You can try click load defaults and then change to 1800kbps and encode. -
Err... no.
Now that you ask it... it seems indeed weird that it makes one pass only. -
VirtualDub does not automatically perform both passes. You have to set everything up, set xvid to Twopass-1st pass, and Save the video. During the first pass Xvid is only examining the video and saving the information in the video.pass file. The video itself will be all black. Then you set Xvid to Twopass-2nd pass and save again. During the second pass it uses the information it saved in the first pass and compresses the video to the requested average bitrate.
If you didn't perform the first pass it was probably using an old video.pass file which has nothing to do with your current video. Hence the problem. -
Ah, now it all makes a lot more sense! Thanks!
So, essentially, I need to re-make the pass every time? That's cumbersome... -
VirtualDub + Xvid: problem with file size in 2 pass encoding.
By marcinkk in forum Video ConversionReplies: 3Last Post: 8th Dec 2011, 15:47 -
AutoGK - XviD to XviD to reduce file size
By marioval in forum Video ConversionReplies: 3Last Post: 16th Jul 2010, 14:37 -
Xvid bitrate and file size problem - Heeelp!
By Salinas in forum DVD RippingReplies: 0Last Post: 10th Mar 2010, 17:05 -
Xvid Encode by File Size Problem
By hech54 in forum Video ConversionReplies: 5Last Post: 1st Jul 2008, 11:45 -
Problem with bitrate and file size when encoding with XviD
By megakoolkid in forum Video ConversionReplies: 13Last Post: 25th Jun 2007, 17:12
