WHAT IS THE BEST BRAND OF DVD-R'S
Verbatim are supposed to be the best but they are expensive.
There has been quite a few posts about it which is the best media.
I guess as a rule of thumb any branded media is good.
You may have to experiment to find the best for you -
There is none. Let me explain some systems are friendly to specific CD brands and some brand hate some cd brands. Not all are the same. Price dose not mean anything. I went 8 different brands before I found a brand that works good on my CD burner and one that works on my DVD player. If you are just storing dat files it dose not matter but it dose if you are making VCDs or burning Mpegs to them it matters.Originally Posted by cyberdrugi
Apple are the best mate, you can get em online from Apple store for about £4
cheaper than verb and just as good, if not better.. -
I've had good luck with the $3.89 "gold" unbranded DVDs from
http://CD-DVD-Supplies.com (Pioneer 333 and Apex 3201).
I haven't tried their $2.89 "silver" unbranded DVDs..... -
So Verbatim - which brand DVD-Rs do you use now?!?
The $3 Optodisc DVD-Rs from newegg.com don't work in my Apex-660, PS2 (nothing has yet, not even Apple's), Friend's Sony DVP-S500, or my roommate's Panasonic 5 disc changer - forgot the model.
Should I buy DVD-R with no brand name?
By greglee in forum MediaReplies: 6Last Post: 16th Aug 2008, 01:49 -
Best brand for dvd-r
By jyeh74 in forum Newbie / General discussionsReplies: 4Last Post: 18th Mar 2008, 00:49 -
Best brand for lightscribe cd's & dvd's
By DonGallego28 in forum MediaReplies: 3Last Post: 7th Sep 2007, 16:41 -
TDK brand DVD+Rs- These any good?
By Super Warrior in forum MediaReplies: 12Last Post: 28th May 2007, 15:19 -
What brand DVD-R is best for the G5?
By Rich W in forum MacReplies: 5Last Post: 23rd May 2007, 20:08
