Hi all,
I use multiavchd for my blueray authoring free time ^^
I use pure blueray title, i use blueray output but here's where i'm a bit In blueray compliant format you have folder like that :
bdmv (where you have all stream asset)
certificate (where you have validation stuff)
AACS (opyionnal: if you use encryption)
-> but <- in multiavchd you get another avchd folder in the root of the disc.
The question is simple : the disc will be 100% compliant or not ? Is it a valid blueray format which i didn't know ?
Thx in advance.
