  1. I converted a RM toan AVI, the Rm was 20 MB, the AVI ended up being 1.98 GB, help me compress the AVI
  2. Does the file need to stay AVI - could you encode it to mpeg using TMPGEnc or something?
  3. Just wondering ... How long did it take for the encoding process to go? ..... and the speed of you PC?
    My site - http://www.sinxation.com
    My Girlfriend's Web Site - http://www.bitch-nation.com
  4. Well - for a 15 min AVI it would take approx 6 hours with a 550Mhz CPU encoding to VCD template. (Using 2nd best motion detection)
  5. Tinra is real time. Ive gotten rm's to Avi's but i get a variety of errors when i try to encode them to mpg, ive even successfully gotten them to mpg and to play on my computer but are not nero compliant?? any ideas??
    Majinbu
    Jul 2001
    Maryland
    Do you have some kind of massive video re-creation filter?
    When I went from RM-AVI, the resulting AVI was crappier than the RM so I said "why am I wasting my time"
    Is their something ur doing to make the avi good and not a huge pile of blocks?
  7. you guys need to use virtual dub after you encode the avi file from rm. Then you need to get a program that will allow you to sync the frame rate up with the sound. Then you convert the avi to mpeg and your finished. It took me about 2 hours to do a 44 meg real media file.
