This may be an easy answer but I cannot for the life of me figure out how to do it.
I am using Authoring Works 4 and have to create a DVD with a lot (45+) individual video clips. Each video clip is named after a person. When adding the clips to the DVD menu, how do I automatically make the track title be the name of the clip.
Instead of:
Track 1
Track 2
Track 3
etc...
....it names it
John Doe
Jane Doe
Steve Smith
etc... based on the actual file name.
This way I do not have to go in and manually name each track based on the file name. Is there any easy way to do this or another program that can do this? Also, can I have more titles on each screen and not use icons?
Thank in advance for the help.
I have not seen any authoring tool that support that.
Go into preferences and select this....
You must do this before starting your project. -
OK I did as you said but once again when I added the clips, they are labeled title 1, Title 2 etc. on the menu..???
Am I doing it wrong? -
That's just for chapter names,not track names,you gotta name all the tracks manually,no getting around it.
You are right, that is for chapters. Why not use chapters instead of tracks? Each clip will make its own chapter within a track....
Separate multiple title DVD into single title DVDs
By Dogpoundz in forum DVD RippingReplies: 4Last Post: 24th Aug 2011, 20:49 -
Toshiba DVR620KU Makes title named Blank Title, when I finalize a disc.
By Dim29 in forum Newbie / General discussionsReplies: 7Last Post: 8th Jul 2010, 21:18 -
How to add a chapter or a title to ONE ONLY TITLE in a DVD?
By coxanhvn in forum Newbie / General discussionsReplies: 4Last Post: 27th May 2009, 23:16 -
How to get a DVD title into a single file
By Case in forum ffmpegX general discussionReplies: 5Last Post: 21st Apr 2009, 05:28 -
DVD main title to single file, with AC3/DTS
By knight76 in forum DVD RippingReplies: 5Last Post: 27th Feb 2009, 11:30
