I am in the process of importing my old MiniDVs tapes with Win DV/firewire into my old PC (XP bases) and then to external drive, because I am about to buy a new PC without the firewire port.
My old PC is formatted as FAT32 therefore each 13gb AVI file is splitted in at least four pieces. Do you see this as an issue for storing my files, and can AVI files be esily joined once I will buy a new PC?
should I then continue to back up my MiniDV tapes this way or should I wait and buy a new PC with firewire? Thank you very much
what do you think it is better do do?
As long as your new pc has one free pci slot you can buy an inexpensive firewire pc card. Than you can do direct captures to a single file on the new pc.
But you should be able to join them together with virtualdub. Just use direct stream copy so as to not reencode them at all. It should be as simple as loading each one and appending them and then saving as a new single file.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
Join m4v splitted with mp4tools?
By Cartman in forum Video ConversionReplies: 2Last Post: 10th Jan 2012, 16:12 -
Joing mkv files when they are not splitted at keyframes
By wateshadon in forum EditingReplies: 1Last Post: 11th Jul 2011, 13:01 -
Problem in merging splitted AVI files of a movie into one.
By nick2712 in forum Newbie / General discussionsReplies: 8Last Post: 2nd Oct 2010, 14:20 -
Joined VOB files... but length remains splitted?
By Metallo in forum Authoring (DVD)Replies: 2Last Post: 7th Nov 2009, 03:44 -
Same VideoFX on scenes that are already splitted
By MyDanny in forum EditingReplies: 2Last Post: 27th May 2008, 19:37
