I have a weird problem with my latest burned AVCHD burned on a DL DVD+R as I usually do. About halfway through, the screen and audio just go black. The disc continues to play, albeit not at a normal rate (seems to skip about 5-6 seconds at a time). At first I thought it was a bad disc so I burned it again but got the same issue. I then burned another AVCHD disc of a different movie and it played just fine. When comparing the two different movies in TSMuxer, they seem to have the same characteristics (Profile, FPS, Resolution, etc.) However, when playing the .m2ts from the "bad" movie in Media Player Classic, it won't allow me to scrub through the movie at all but I have no problems doing so with the "good" movie. Any ideas on what the problem could be?
	No idea how to fix it. Just re-encode it from scratch. Recommends: Kiva.org - Loans that change lives.
 http://www.kiva.org/about
	Bad disc? Many people don't know that ONLY Verbatim DVD+R DL discs are reliable DL media. I'll bet that you didn't use Verbatim.
	And I'll bet you that I did
 The problem seems to lie with the .m2ts file itself since I have trouble playing it back on my computer, whereas I can play other .m2ts files with no problem. As edDV said, I'll probably have to re-encode since something probably went wrong during that process.
  Ps3 Black screen on moviesBy Fenrirjack in forum Blu-ray RippingReplies: 10Last Post: 21st Dec 2011, 18:18
  How to apply a black screen on playback?By therock003 in forum Newbie / General discussionsReplies: 12Last Post: 1st Sep 2011, 04:41
  AVCHD DVD playback on PS3 failedBy joe4yoshimi in forum Video ConversionReplies: 1Last Post: 29th Dec 2010, 22:54
  PS3 Stops Playback of AVCHD?By tommy2010 in forum Authoring (Blu-ray)Replies: 1Last Post: 15th Dec 2010, 02:38
  black screen on ps3 after converting videoBy unknownguy in forum Video ConversionReplies: 1Last Post: 22nd Jan 2009, 07:26
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
