    Aug 2005
    AKL, NZ
    Hi good people, Hopefully someone can explain or point me in the right direction please.
    I would like to "step" through the coding on a Bluray movie so I understand exactly which movie file
    is played for my given set of instructions. For example the scripting for extended play verses theater version.
    I can follow DVD script with PGCEdit so hoping I can do the same with a Bluray script.
    Regards and thanks up front.
    USA
    You can get some info with the BDInfo program.
    Aug 2005
    AKL, NZ
    Cheers redwudz. I was hoping for more information on how the script of a disc arrived at the choice of movie stream
    playing if it was in a normal player.
    Aug 2005
    AKL, NZ
    Originally Posted by videopoo View Post
    Cheers Videopoo, I have been working with your advise... great tool too.
