Thanks in advance for any answers. I'm attempting to combine 2 seperate m2ts files through tsremux. When adding both files (not from bd folders, just single m2ts sources) I can mux an m2ts which contains both vids. Each plays fine except, when the first vid stops, it doesn't start the next title/vid (my second m2ts). When I try the join option, it combines perfectly giving me my singular m2ts file. The problem is I experience an audio delay in the second title/vid of about 1 second. After some "slight" research (check my user name) I discovered that both have different frame rates. The first vid is 24 fps, while the second is 23.9xx (registers as 24000/1001 in tsremux) ...... ?
I could try the -1 audio delay, but I don't think that's the right direction. I've read much about having the same cropping/sizing and that you must have the same frame rate to join the files. When I added them everything was fine but it didn't skip to the next vid... ???? how do I fix my insanity? again thanks.
Thread can be closed. No answers and I found a roundabout way. I used multiavchd, to change the fps to 24 (from 23.97).. now that they both matched, I used tsmux to join them, without any audio delay.
Help with multiple .m2ts files to one .m2ts
By neworldman in forum Blu-ray RippingReplies: 10Last Post: 4th Sep 2013, 10:16 -
Using mencoder to join mpeg video result in a/v out of sync.
By Jemore in forum EditingReplies: 3Last Post: 18th Jan 2012, 02:02 -
Merging/Converting Multiple M2TS files to MKV With Multiple Audio Tracks
By Nicholas S. Folsom in forum Video ConversionReplies: 1Last Post: 13th May 2011, 18:34 -
An M2TS file went thru TSRemux and has come without any file association
By mahogany in forum Newbie / General discussionsReplies: 4Last Post: 2nd May 2010, 09:04 -
Does change of FPS of DVD result in any problem
By maass in forum Newbie / General discussionsReplies: 2Last Post: 20th Mar 2009, 07:58
