I am having issues playing blu-ray's and dvd's through ArcSoft Total Media Player,CyberLink PowerDVD 10,and possibly more...so far the only thing that has worked is Media Player Classic. My issue is everything plays, I have all music,background noises,etc but, I have no voices! If anyone has any ideas please let me know!
Jake
PS I wasnt sure where to put this so I just used newbie section!
Sounds like the players are picking 5.1 audio when you only have stereo "hardware".
Just to add, with 5.1 or other surround sound sources, the center channel usually has the dialog on it. But if your system is two channel stereo, you can set it to that and it should downmix so you can hear the center channel. Check your audio card settings. If you do a have 5.1 or better surround system, let us know and there are other things you can check.
Thanks guys! I checked my audio properties and thats what it was! Everything appears fine now!
issues playing burned DVD's on sony blu ray player bdp-s300
By cdcutlip in forum DVD & Blu-ray PlayersReplies: 2Last Post: 7th May 2011, 16:12 -
Blu Ray issues
By Jon Gallo in forum Newbie / General discussionsReplies: 0Last Post: 17th Mar 2011, 13:28 -
Blu-ray Audio Video Sync Issues
By nerouser in forum Authoring (Blu-ray)Replies: 1Last Post: 24th Feb 2009, 16:38 -
Can I rip Blu Ray Discs with LG Super Multi Blu-ray Disc and HD DVD-ROM Dri
By donpato in forum Blu-ray RippingReplies: 5Last Post: 5th May 2008, 17:05 -
I am Legend Encoding (Blu-ray) audio sync issues
By Ansuer in forum Blu-ray RippingReplies: 21Last Post: 1st May 2008, 18:54
