Here is the road I took to my problem of not being able to view a split movie, after merging the two parts in the burn process:
1. I used Aegisub to edit subtitles for each of the two AVI files.
2. I saved the subs in the .SRT format but also tried .SSA and .ASS when the project using .SRT failed.
3. I used ConvertXtoDVD to convert the files to DVD and hardcode the subs (I also tried the same with AVS Video Converter).
4. Both DVD parts play fine on my PC.
5. I used the 'Merge" option in DVDFab that has always worked for me to burn the two parts onto a DVD disc, but on this occasion only part 1 of the movie will play after burning to DVD media.
6. The DVD disc that plays only part 1 contains 4.35 GB of info (IFOs, BUPs, VOBs); so I figure both parts were burned onto it, since each part is about 2.2 GB when converted separately to DVD.
7. I tried to hardcode the subs with VirtualDub, but the subs appeared fuzzy, even though they looked crisp in VDs preview feature.
8. I also used ConvertX to merge the two parts and wasted another disc. For some reason. only part 1 will play once the two parts are merged and burned to DVD media.
I did burn the movie on two DVDs, which play fine. I suppose I could use the break to change disks as an opportunity to make some popcorn. But I'd like to learn how to overcome this problem. Has anyone encountered this issue before?
Djard
medfaith@yahoo.com -
Why not join them in convertxtodvd and save yourself a step. Add the first part, append the second, and convert.
Read my blog here.
Thanks for the response. Yes, I tried that; but it didn't work the first two times.
I ended up overcoming the problem by using additional steps, firstly double-checking the parameters for placement of subs in ConvertX are identical to those in Aegisub -> merged the two parts with their subs using ConvertX, used DVDShrink to reprocess the movie (it grew to 4.58 because I encode with a setting of 4800 MB to overcome too much compression--ConvertX converts a 4.3 GB MKV to a < 3 GB DVD, reducing image quality). Then I used DVD Decrypter to burn the movie to disk. The only difference was avoiding DVDFab and using DVDShrink to re-rip and burn with DVD Decrypter.
I saved the same SRT file in SSA and ASS formats, but only SRT worked, which is also strange. I suppose occasionally some small encoding error fools even the best apps.Djard
medfaith@yahoo.com
Merge multiple audio tracks from different files into 1 video file - sync
By heinza in forum Newbie / General discussionsReplies: 2Last Post: 11th Jan 2012, 03:29 -
Is there software to merge dozens of video files into 1
By jbitakis in forum Video ConversionReplies: 1Last Post: 3rd Dec 2011, 04:06 -
Merge video files in DVD Flick?
By morgle in forum EditingReplies: 6Last Post: 13th Aug 2010, 10:28 -
Merge 3 part XviD AVI
By Benhermies in forum Newbie / General discussionsReplies: 3Last Post: 5th Jun 2009, 22:45 -
How can I merge two video files into one?
By DVDNewb in forum Newbie / General discussionsReplies: 24Last Post: 17th Mar 2008, 13:58
