Results 1 to 9 of 9
  1. Hi ... I have this blu ray movie which is split into many MZ TS files ... Is their any free software that can join them all into one big MZ TS file ? I recognize these files when I right click on them and select properties Windows xp show these type of files as MZTS . I would love to be able to join them all together . Thanks
    And sorry if this is in the wrong section ...
  2. Do you mean m2ts? if so try tsmuxer.
  3. Yep , that is what I meant and thanks for the software ...
    Mar 2011
    Washington
    I have an additional question in this topic. Is there any way to get the playlist information of the disc for a movie that is in many .m2ts files or do I have to go through each file and figure out a play order? Thanks in advance for the help.
  5. I'm a MEGA Super Moderator Baldrick's Avatar
    Use bdinfo to identify the playlist. Then open the playlist file in tsmuxer.
    Mar 2011
    Washington
    Thank you. I will try that.
  7. Hi ... if I use bdinfo to gather the playlist , how do I add them into tsmuxer ? And I also must have the disc for the info , right ? I mean I can't just use the files copy onto my hard drive instead ? Because every time I try to use tsmuxer and add files from my hard drive I get an error , tsmuxer not found ... So I must have the movie disc in the optical drive to use bdinfo and tsmuxer , right ? Thanks
  8. I'm a Super Moderator johns0's Avatar
    canada
    Load the playlist itself into tsmuxer,it will add the files needed.You won't need the disc,long as you have all the files on the hdd.
  9. Originally Posted by johns0 View Post
    Hi ... This is what I am asking , how do you load the playlist with bdinfo unto tsmuxer ? Thanks
    By any chance would their be a youtube video one can watch as to how its done ?
