I have a bunch of MKV videos, each with 4 subtitle sets. I assume that takes up a fair amount of space... I used mkvmerge to 'de-deselect' the sub files but I think it just disabled them rather than remove them from the container because the file size is the same.
My other options as I see it to reduce the size of these MKV files is to compress the video or convert to AVI which is what my other video files are.
Which of these 3 options would be easiest for a newbie and what programs should I use?
Thanks!
MKVMerge removes them. You can easily confirm this by comparing a MediaInfo log of the original with subs and your subs removed version. The removed subs version will not have a heading at the bottom of the log TEXT. Or you could run the removed subs version through MKVMerge to see if you can "put them back" I think not!.
As the previous post said subs only take up a very small amount. Re-encoding to avi etc will reduce the file size depending on what you want but you will lose quality. As an alternaive if the sound track is 6 channel AC3 or DTS you could convert down to 2 track MP3 audio (also a loss of quality but may be a better trade off than the video)SONY 75" Full array 200Hz LED TV, Yamaha A1070 amp, Zidoo UHD3000, BeyonWiz PVR V2 (Enigma2 clone), Chromecast, Windows 11 Professional, QNAP NAS TS851
External subs don't play correctly with Anime .mkv with embedded subs (.ass
By Reveur in forum Software PlayingReplies: 1Last Post: 8th Nov 2011, 02:20 -
Does mkvmerge reduce quality when removing subtitles?
By Moth Queen in forum Newbie / General discussionsReplies: 2Last Post: 25th Feb 2011, 22:06 -
Reduce file size .
By pensioner in forum Newbie / General discussionsReplies: 4Last Post: 10th Dec 2010, 14:08 -
mkv question... many mkv files (with subs) into 1 mkv?
By 0okami in forum EditingReplies: 1Last Post: 24th Oct 2009, 00:45 -
Full conversion MKV subs to avi subs & fonts intact.
By ashidosai in forum Video ConversionReplies: 28Last Post: 18th Oct 2008, 16:36
