Hello all,
I am looking for an All Region DVS/VHS player, that will play any region DVD and any region VHS tape. And also has the ability to transfer the VHS tapes to DVD.
Does such a player exist? I don't need the ability to record shows from TV or have a DVR function. Just an all region player of DVD/VHS and the ability to record those VHS to DVD.
Anything?
Thanks!
What you'll need is a multi-system VHS player like this one feeding an NTSC or PAL DVD recorder.
http://www.hometechanswers.com/video/samsung-sv5000.htmlRecommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
Also don't confuse this VCR with the cheap $50 "multi-system" VCR's that can be purchased. The above expensive VCR is a "converting" VCR(it can convert between PAL and NTSC). All European VCRs are "multi-system" and very inexpensive but will not work in the USA without an additional external converter. -
@ the original poster - you'll get this suggestion soon enough so I'll go ahead make the suggestion:
If you only have a handful of tapes to convert send them to a professional service. That will be far far easier and most likely cheaper than doing it yourself. You should get much better results than doing it yourself. And unless you have a tbc you'll probably won't get adequate results anyway even if you got a vcr that plays it properly (though your mileage may vary).Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
Euroline DVD100 DVD Player Region all region code/hack?
By mjgjhb in forum Newbie / General discussionsReplies: 0Last Post: 21st Jul 2011, 10:26 -
Region Free DVD Player Question
By notridgid in forum DVD & Blu-ray PlayersReplies: 2Last Post: 7th Dec 2010, 18:57 -
DVD multi-region player question...
By mjl1297 in forum Newbie / General discussionsReplies: 8Last Post: 26th Apr 2010, 06:05 -
ATSC Tuner Question with DVD Player/Recorder/VHS Combo Unit
By Surfmaster in forum DVB / IPTVReplies: 4Last Post: 17th Dec 2007, 21:01 -
question about various YouTube online recorders/converters
By jimdagys in forum Newbie / General discussionsReplies: 1Last Post: 31st Oct 2007, 11:49
