I have in the past been able to use the batch downloading feature for streamtransport. However it seems for awhile now it won't work.
I have version 2171
I can download the 4 at a time that it lets you do simultaneously. However when I load up a list of say 10 or 15 more it will not start the next batch. It tries and then fails. I also can't resume it manually by clicking on the resume button.
This is a problem since I'd like to setup a batch download overnight. Without the task list working to start the next batch of 4 downloads I have to manually set them up. That makes it a lot more difficult.
Is this just common to some websites or has this been blocked somehow by websites? I can get the files just fine but only four at a time and I can't load them up and walk away for a background download.
Is there a way to copy and paste the url to add them to a download manager program somehow? I tried clicking on the line that shows the length of the video and I can't seem to access the url in that window (the line you use to click the download button and start the download.
Thanks for your help.
Edit - I am going to check out xVideoServiceThief. It says it can do rtmpe websites. I'll see if it can do the sites I'm using and if it has a batch mode. I hate to not use streamtransport but the lack of a working batch mode is a big negative for me.
Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
Sites can block multiple connections from same ip.
Does it happen for all sites? -
@baldrick - it appears to.
Would having multiple sessions of streamtransport do the trick?
Also I did check out xVideoServiceThief but I don't see how it can do the downloading the same way as streamtransport. It seems to require the actual url to do the downloading.
I am not sure how to copy the correct url in streamtransport to xvideoservicethief. I selected a video to download in streamtransport and then downloaded it. I opened the task window and copied the url that it showed in the text box. However when I copied and pasted it into xVideoServiceThief I didn't get anything. There was no video downloaded.
I looked into urlsnooper and rtmpdump but did not have a successful trial with either. Urlsnooper didn't seem to get a valid link but I could easily be doing it wrong. And frankly I'm not sure how to use rtmpdump. I'd be in need of a link for a guide on that.
Basically I'd like to gather all the urls I need for the set of videos I'm after and then load them into either xVideoServiceThief or possibly eve a regular old download manager if I get the "naked" url of the actual video itself.
Thanks again.
EDIT - Well at least on one site I was having issues at I CAN do at least two windows of streamtransport for simultaneous donwloading. So I can at least max out at 8 downloads - 4 per window. I don't know if I want to push it to another window or not. I'm not sure how that would affect speeds.
But at least now I can double my efforts. I still have to go back and manually set up the next batch of 8 but that is a lot better than manually doing every batch of just 4.
EDIT 2 - EUREKA! I have tried adding a 3rd window of streamtransport and IT WORKS! Now I am actually doing 12 simultaneous downloads!! The speeds seem to be about the same. How it does that I don't know. Now I'm moving much more efficiently.
It was so annoying having to load just 4 at a time. So inefficient. Now 12 at a time is even better!!!!!Last edited by yoda313; 26th Mar 2011 at 08:46.
Can streamtransport save as an original mp4 instead of flv?
By yoda313 in forum Video Streaming DownloadingReplies: 4Last Post: 18th Jun 2012, 16:37 -
Substitute to Streamtransport !
By augustya in forum Software PlayingReplies: 9Last Post: 15th Jul 2011, 12:30 -
Looking for a mix of GetFLV and StreamTransport
By TrayVH in forum Newbie / General discussionsReplies: 0Last Post: 24th Apr 2011, 11:45 -
Feature REQ:True batch encode
By tszpara in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 19th Jan 2010, 04:30 -
[Feature Request] Please add batch video conversion option!
By Panarchy in forum ffmpegX general discussionReplies: 0Last Post: 20th May 2008, 07:13
