Results 1 to 10 of 10
  1. Is there a program out there that can span a series of DVD-R discs in the most efficient manner? I have a series of videos that I want to burn on the fewest DVDs as possible.
  2. Banned
    Jun 2004
    ®Inside My Avatar™© U.S.
    And martian is your first language ?
  3. No, I should really avoid typing things after drinking.
    I'm trying to make the most efficient use of the dvd-r discs, and was hoping there was some software out there that did this for me.
  4. Banned
    Freedonia
    Short answer - No.
    Somewhat longer answer - You can do it yourself if you're willing to do the work, but nobody has written a program for this task because basically almost nobody but you wants to do this and there are too many variables involved to make this practical. I could quite probably get 20 or maybe even many more videos on a single DVD-R but you're not going to be happy with the results. If you know how many videos you want to put on a single disc there are programs that will convert them to DVD for you.
  5. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    If they are video "clips" and you are burning them as DATA then by all means there are programs for that.
    http://hcidesign.com/dvdspan/
  6. PSCO2007
    May 2010
    Southern Ca.
    If I understand you, you want to burn more than one movie on the same disc.
    I do this all the time - Use Dvdshrink > go to "reauthor" and import the movies from your hard drive.
    Go to "compression settings" and reduce until the green line is all you see.
    You can burn two movies this way, but the output may be reduced and not to your liking.
    Give it a shot.
  7. Banned
    Jun 2004
    LOL!!!
    Okay ya got me on that one!!!
    LOL!!!
  8. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    No....not even close.
  9. PSCO2007
    May 2010
    Southern Ca.
    Why don't you give me your "expert" opinion, since he said he wanted to burn the most videos on the fewest dvds possible.
  10. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    Gee I don't know....how about the word "videos" and not "movies". You know that word....you just used it.
