Is there any way to tell what encoder program was used to encode the video on a dvd? For example, would there be any meta information in the m2v file that would tell you? What program woudl I used to access that info?
What about the authoring program that was used to create the menus?
Thanks!
As you thought, gspot isn't ginving me the info when I examine the VOB file of interest, although it seems to pick up come info when you use it to look at an avi file.
The reason I want to know is that a dvd sold by a company sticks or stutters at a specific spot for a number of customers who have complained. The company said there is nothing wrong and the prblem is with their dvd players that can't handle the high bit rate at that point in the video. I used the DVD Bit Rate View program to check, and the bit rate is actually rather low at that spot as there is not much motion in the squence. The company is being as*holes to customers - I am suspecting some sort of encoding error on their part which they want to deny. I wan tot find out what ecoder they used so I can be more knowledgable when I next talk to them. I suspect they think their customers are all too dumb to look into these things.
Freemake video encoder video gets green screen
By flashcabaja64 in forum Video ConversionReplies: 7Last Post: 20th Mar 2012, 20:23 -
How it possible Video: X264 encoder with Matroska encoder extension?
By flash_os in forum Newbie / General discussionsReplies: 1Last Post: 11th Feb 2012, 09:13 -
Your Best Video Encoder/Re-encoder???
By iqbal88 in forum DVD RippingReplies: 2Last Post: 15th Aug 2011, 08:09 -
Help with video encoder
By massivegroove in forum Newbie / General discussionsReplies: 0Last Post: 15th Jul 2007, 09:59 -
Video EnCoDer!!
By Unkn0wn in forum Newbie / General discussionsReplies: 5Last Post: 7th Jun 2007, 10:57
