  1. Hello,
    i'm looking for a TV/converter box with the following features:
    • component (YPbPr) + audio input
    • HDMI output
    • upscaler (e.g. from 480p to 1080p)
    • deinterlacer (e.g. from 480i to 480p)
    • 5v-powered
    I'm planning to use the box with my HP 2159 computer monitor that supports progressive video signal only.
    Jul 2001
    Monoprice being my favorite cable and converter place to shop:
    A Component (or VGA, w/sound option) to HDMI:
    http://www.monoprice.com/products/product.asp?c_id=101&cp_id=10114&cs_id=1011404&p_id=...seq=1&format=2
    Your monitor has VGA as well, so you could try this for a little less money:
    http://www.monoprice.com/products/product.asp?c_id=101&cp_id=10114&cs_id=1011407&p_id=...seq=1&format=2
    NOTE: Do NOT get any of the component to VGA cables. A converter is needed for what you want to do.
    Have a good one,
    neomaine
    NEW! VideoHelp.com F@H team 166011!
    http://fah-web.stanford.edu/cgi-bin/main.py?qtype=teampage&teamnum=166011
    Folding@Home FAQ and download: http://folding.stanford.edu/
  3. Thanks for your suggestions.
    I prefer shopping from dealextreme.com because shipping to my country from USA is more pricey.
    I've found very similar products in their shop:
    http://www.dealextreme.com/p/ypbpr-component-video-to-vga-converter-22845
    http://www.dealextreme.com/p/component-video-ypbpr-to-hdmi-converter-box-with-spdif-au...io-input-29772
    http://www.dealextreme.com/p/vga-component-video-audio-to-720p-hdmi-v1-2-converter-100-240v-ac-22317
    BTW i'm not totally sure they perform deinterlacing and upscaling.
    Also i prefer HDMI over VGA because it is digital (better quality) and can carry both video and audio signal with a single cable.
    Aug 2006
    I read some of the reviews, and it appears most of analog to HDMI converters don't upscale. The one I saw that does upscale has a set resolution of 720p. They are intended for use with TVs, or other AV equipment, so they generally don't de-interlace either. I doubt that the item you want exists.
    [Edit] I don't know what source in your country has it, but here's a link to the one I found that upscales to 720p: http://www.amazon.com/gp/product/B0016SN49Y/ref=pd_lpo_k2_dp_sr_2?pf_rd_p=486539851&pf...DDE859PGRQ2605
    [Edit 2] Never mind. It looks to be the same thing as the item in the third link in #4 above.
  5. Originally Posted by usually_quiet View Post
    A fixed 720p upscaler isn't a good solution because my monitor has a native resolution of 1920x1080, so the image would be upscaled 2 times (the 2nd by the internal monitor processor), would lose quality and timing.
    Instead i've found this one that is closer to what i was looking for:
    VD-W3 Wii HDMI Upscaler Processor
    It's a bit pricey and wii-specific (can't be used with other consoles), but it seems it does the job.
    Aug 2006
    That link shows a price of $59 for me. If it performs adequately, then you should consider yourself lucky to have found anything at all that can work with your console and a monitor instead of a TV, let alone something that inexpensive.
  7. Another wii-specific upscaler is HDMIKey (still to be released).
    Sadly, all the general purpose component-to-HDMI upscalers i've found are very pricey.
