This is weird. I generally use ConvertXtoDVD to make my dvd (usually converting an AVI file or occasionally and MKV). Last night an AVI file I made with ConvertXtoDVD just wouldn't load and play. A previously converted file worked just fine. I don't recall if the 2nd dvd was an avi file originally or not, but odds are it was.
Does anyone have an idea what may have happened? The dvd itself was from a batch of Memorex I have not had any problems with.
Thanks!
Hal
I'm afraid. I'm afraid, Dave. Dave, my mind is going. I can feel it..... Yup. Spppllttt. It's gone.
bad disc most likely. only verbatim and taiyo yuden are worth purchasing. and no "life series" or seconds even from them.
Did you save the output on the hard drive and test the dvd-video from the hard drive? Maybe you had a glitch in the conversion process.
Does anyone know for sure if something like an automatic antivirus update can screw up a DVD you are making, either in the conversion / encoding or the burning phase ? Because I have some suspicions about this, if the project is more important I am apt to unplug the ethernet cable while CX2D, AVStoDVD, or other video processing programs are doing their thing.
But yeah -- avoid Memorex and all the other crap media most people buy, if you want to maximize your chances for obtaining good results.Looking for Rare / Obscure / Hard-to-Find Films ? Check out http://rarefilmm.com/ , and also its Requests & Discussion forum http://rarefilmm.chatango.com -
Given that virtually any program can crash Windows, yes, any program could screw up your DVD build/burn. But aside from catastrophic failures like BSODs, lockups, and spontaneous reboots, it's very hard for one program to screw up another in modern operating systems. The exception would be real time processes (where the CPU must respond to a hardware event within a certain amount of time) like video capture and DVD burning. The latter is largely alleviated by "burn-proof" and other buffering technologies.
So it's not likely that another process could screw up the conversion and authoring steps, and only slightly more likely that burning could have been messed up. But there's always the possibility that the software that was used, ConvertXtoDVD, just screwed up on its own. -
Could it be you inadvertently made a PAL DVD and your NTSC player rejected it ?
Half of DVD Doesn't Play
By theWallflower in forum Authoring (DVD)Replies: 19Last Post: 20th Dec 2011, 23:08 -
Replacing DVD menu made by ConvertXtoDVD
By crackerbear in forum Authoring (DVD)Replies: 3Last Post: 4th Oct 2010, 05:39 -
iTunes doesn't want my MP4-AVC movie for my iPhone [made with Yamb]
By Kenjin in forum Video ConversionReplies: 7Last Post: 19th Sep 2010, 15:55 -
DVD Made on Your Recorder Play on Another Brand?
By retexan599 in forum DVD & Blu-ray RecordersReplies: 6Last Post: 19th Jun 2008, 13:12 -
DVD+R Doesn't play after halfway through
By cfresh13 in forum DVD RippingReplies: 9Last Post: 21st Mar 2008, 20:28
