I made a video and I want it to stop after a song, How do I delete the end of the video? Or bleep out some talking in this section? Thank You
Depends on the video format you're using. For AVI type videos, try VirtualDub. For MPEG videos, AVIDemux. AVIDemux can also handle AVI type video, so may be a better place to start.
Most highly compressed video formats like Xvid, Divx, H.264, have widely spaced keyframes (I frames) and frame accurate cuts are very difficult without re-encoding, at least at the cut point.
For the audio, you may be able to do that in the video editor, or extract it and use a audio editor like Audacity to fix it, then combine it back with the video.
There are guides for those programs on their tool pages.
And welcome to our forums.
I used a FUJI 2500 camera. I recorded my son singing in the concert, but at the end I was talking and I don't want that kept for him to post or share with friends. lol So I downloaded the video to my computer desktop, but do not know what do from there. This is my very first video I ever made. Thanks so much for helping.
Make sure you have the original video stored in case of problems. Work with a copy.
Try opening it in AVIDemux. The video format seems to be MJPEG, so easy to work with. The audio is apparently WAV format. Also easy to work with.
If you need to edit the audio, you can demux it and open it with Audacity, then correct it and mux it back. AVIDemux should be able to do that.
Take video from a dvd, shorten it, convert to YouTube format?
By gary.brook in forum Newbie / General discussionsReplies: 3Last Post: 31st Jul 2008, 20:38 -
To Shorten a DVD
By bryankendall in forum Newbie / General discussionsReplies: 2Last Post: 1st Jan 2008, 17:00 -
clip/shorten video
By fredct in forum ffmpegX general discussionReplies: 2Last Post: 17th Oct 2007, 02:13 -
Low End Video Card w/ adapter vs. Low End DVD player
By enter8 in forum Media Center PC / MediaCentersReplies: 6Last Post: 20th Aug 2007, 16:45 -
how to shorten a video
By legionarios in forum EditingReplies: 1Last Post: 16th Aug 2007, 13:55
