Hi,
I want to use this device to stream media content to a Sony Blu Ray player (BDP-S370), but I am not sure whether it will work?
I have found a pretty easy way of converting my DVD's to a Lossless (1:1) MKV file but unfortunately the output MPEG MKV file will not play on the Blu Ray player (via USB).
If I were to run the same file through the HD2 to the Blu Ray player would it work? Does the HD2 transcode the file into a type the Blu Ray player can read or will it not work period?
The same quetion applies if I were to rip my DVD's into DVD/BD-ISO files.
The Blu Ray player will be connected via Ethernet in a different room to the HD2.
Regards
J
I don't think the PlayOn!HD2 acts as a DLNA server. So you can't stream from it to your Blu-ray player. You might be able to have it act as a file server but that would be the same as Windows or Linux acting as a file server -- if the Blu-ray player doesn't play MKV files it won't play them from any file server.
But the PlayON!HD2 is a media player -- just hook it up to your TV and use it to play your videos. -
Thanks for the response. I have every intention of hooking the HD2 up to the TV in the Lounge/Main Room, but I want to be able to stream the contents to a TV in a different room (via the Blu Ray Player) over a wired network? Is this possible?
J -
I think for your needs you need to read the manual of the exact device you plan to buy.
If it can't do what you want look into another device.
In the end you can always return it for a refund if you buy the device new if it doesn't do what you want.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
Fair Shout, I have e-mailed AC Ryan to ask whether this is something their device can do. No Response from them as yet. I wanted to see whether anyone else is doing the same thing.
Cheers. -
I saw no indication the PlayOn!HD2 can act as a DLNA server.
http://www.acryan.com/forums/viewtopic.php?t=878&f=39
Does Playon!HD support DLNA?
Currently No, DLNA is not yet implemented
Is PlayOn the only way to get Hulu on my TV via PS3?
By marioval in forum Media Center PC / MediaCentersReplies: 6Last Post: 16th Aug 2011, 19:18 -
PlayOn and Roku, Playlists how? Not Possible?
By sum_guy in forum Video Streaming DownloadingReplies: 6Last Post: 3rd Apr 2011, 12:23 -
Crossover cable / AC Ryan PlayOn
By ringo12 in forum Media Center PC / MediaCentersReplies: 3Last Post: 9th Nov 2010, 09:38 -
Watching movies on HTC HD2
By me-eyes in forum Portable VideoReplies: 2Last Post: 2nd May 2010, 16:02 -
PlayOn Media Server Half price, $19.99
By handyguy in forum Video Streaming DownloadingReplies: 1Last Post: 28th Jun 2009, 13:03
