Hi all.
Whew, i've combined community codec pack installed (with mpc-hc included) and run perfectly until a few hours ago.
Then suddenly, upon trying to play a video with mpc-hc, a message popped up, "Warning: Creating EVR Custom Renderer .... The installed DirectX End-User Runtime is outdated. Please download and install the June 2010 release or newer in order for MPC-HC to function properly."
As a result I went to here and install the latest directX.
Now, every time I play any video with mpc-hc, it will just crash and stop working. I tried VLC, it still works normally.
This problem then added by error message ".Net runtime optimization service stopped working and was closed" every time computer start-up. I'm not sure if it's linked with the mpc problem.
Anyone also got the same experience..care to share if you know one or two solutions?
Thanks a lot!
I changed to system default, now it works.
However, upon playing .mkv (with codec H264-MPEG-4 AVC) there would be no display, only sound.
And .rmvb cannot work as well - "mpc-hc could not render some of the pins in the graph, you may not have the needed codecs or filter installed on the system : Output 00 (Audio Stream)." Only the picture displayed, no sound.
Other format i've tried (avi,mp4,flv) works properly though.
Previously, all formats work properly.
Note: Since the error, i uninstalled the cccp, and install k-lite codec pack full.
Thanks for who replied. I appreciate it.Last edited by darkw1zard; 24th Mar 2011 at 03:50.
Need help-Been using ripbot for sometime now....it has stopped working.
By clefus in forum Blu-ray RippingReplies: 3Last Post: 13th Jan 2011, 12:42 -
SVCD2DVD Stopped Working
By magic90 in forum SVCD2DVD & VOB2MPGReplies: 8Last Post: 28th Sep 2010, 08:07 -
Why have my TV speakers stopped working?
By jimbo7777 in forum AudioReplies: 6Last Post: 17th Apr 2010, 19:19 -
Capture stopped working
By Movie-Maker in forum Capturing and VCRReplies: 4Last Post: 28th Mar 2010, 22:15 -
No desktop icon or Start menu with MPC Classic?
By mikehende in forum Newbie / General discussionsReplies: 9Last Post: 29th Mar 2009, 19:54
